best way to cut tungsten ?
  • best way to cut tungsten ?
    guys, how do you cut your tungsten in half, when using a stubby back collar ?
    thanks
    Syncrowave® 200
    Lincoln AC/DC 225/125
    Lincoln Weld Pak 100 wire feed
    Wack it with a hammer on a metal 90 edge of your work bench.
      Bench grinder!
      Score the tungsten on the edge of the wheel then break it.
      Caution!
        cool. i have used the hammer and end of the table trick a lot, but sometimes one part flies and cant find it, or it will break uneven.
        i will try to score it on a grinder and then break.
        thanks
        too bad someone dont make a tool for this
        Syncrowave® 200
          Arc-Zone.com : Tungsten Grinding Machines - Connectors, Cable, & Adapters MIG Guns, Feeders & Parts Plasma Arc Cutting Plasma Arc Welding Purge Gas Equipment Remote Amperage Controls TIG Torches & Accessories Tungsten Electrodes Tungsten Electrode Grinders Water Coolers, Coolant & Parts Gas Flowmeters, Heaters, Mixers Stick Electrode Holders Shop Tools & Storage Apparel, Helmets & PPE Oxy Fuel Cutting & Welding Ground & Work Clamps TIG Welding Filler Rod Close-Out Products Welding Machines & Upgrades Weld Tables JIG & Fixturing Tools Automation & Positioners
          Ed Conley
          MM252
          MM211
          Passport Plus w/Spool Gun
          TA185
          Miller 125c Plasma 120v
          O/A set
          SO 2020 Bender
          You can call me Bacchus
            wow. we have one at work, but never knew they have the cut off option. i will check ours today. thanks
            Syncrowave® 200
              That will work no doubt about it but you run the chance of seperating the strands some, this can cause arc wander untill you sharpen your way out of the affected area. This can sometimes take 5-6 sharpenings.
              YMMV of course but I just wanted to let you know what was happening there. You may have allready experienced this by not breaking it clean and taking another shot at it and then sharpening the fuzz. (go on, ask me how I know all this ;-)
              best regards,
              Jake
              Miller 251
              Miller Trailblazer 280nt
              Miller Maxstar 200dx
              Lincoln Squarewave 185
              Acme 20kva spotwelder
              Hobart buzzbox
              Thermal Dynamics plasma cutter
                yep, our tungsten sharpener at work has the cut off option, and i used it today. i feel stupid for not noticing it earlier. worked great.
                thanks
                Syncrowave® 200
                  thanks
                  A tool is made for this procedure.
                  Griff
                    fool proof solution.
                    Use the hammer and edge of the table but wrap it in a rag or put it in an old glove. I ont use the gloves I ware I saw a guy do that once and end up with tungston in his finger. -Kirk-
                    Just cause I ain't old don't mean I ain't old school.
                    "Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity."
                    -Gen. George Smith Patton, Jr-
                    If you don't like the sparks and flame you can always be a desk jocky pencil pusher.
                    You soul better belong to jesus because your @$$ belongs to me.
                    -MEGADETH-
                      you can buy a diamond wheel for a dremel or die grinder for very little money. you could also scavenge from a cheap used tile saw. If your a little patient, you can use the diamond wheel in a drill. Checkout ebay.
                      Millermatic 175
                      Spectrum 375
                      All kinds of Smith OA gear
                        I was just reading on this forum in resources that Miller recommends breaking the tungsten over an edge to cut it. I've read that this is not the best way to do it because it can splinter and cause stress cracks. Hmmmm
                        Nick
                        Miller 252 Mig
                        Miller Cricket XL
                        Millermatic 150 Mig
                        Miller Syncrowave 200 Tig
                        2-O/A outfits
                        Jet Lathe and Mill
                        Jet 7x12 horz/vert band saw
                        DeWalt Multi Cutter metal saw
                        Century 50 Amp Plasma Cutter
                        Propane Forge
                        60" X 60" router/plasma table
