Originally posted by con_fuse9
View Post
Bosch grinders???
Guys,
What most of yall don't understand is, grinders are a consumable item. It doesn't matter what brand you have, they will eventually all wear out. Just some faster than other. Right now in current operation, I have 11 of the smaller grinders (4-1/2" , 5" and some 6" ones) and I have 3 of the larger grinders (7" -9" ones). Yes they do wear out and break. You just have to spend the money and replace them. I look at it like this. Gun liners, or nozzles are consumables but they don't need to be replaced as fast as sand paper, grinding disc, or contact tips. But the nozzles, and gun liners, do wear out and need to be replaced. Same as the grinder itself. When It wears out you just junk it, and get another one. I'm not going to loose sleep over it, that's just part of owning a business.
Second. a lot can be done to extend the grinders' life (the Dewalt, Makita, Bosch etc.... not the persons life, but yes safety precautions do need to be followed). Don't use a 4-1/2" grinder to do the work of a 7" or 9" grinder. I see people all the time take a small 4-1/2" grinder start it up and bear down on it. Like they are putting all their weight on this little grinder. That will break/kill/ or wear out the grinder very quickly. If you need to grind that much material where you are having to really "lean" into and bear down, go get the 9" grinder.
But the ones I like are the 4-1/2" 10amp Dewalts with the paddle switch. They seem to be the right size to fit your hand, have some power, are cheap, and last "long enough".
-Ryan
Home depot dropping bosch grinders....
Web site doesn't have them anymore (they do carry other Bosch tools though).
So I went to the local HD, and they had only the floor model left. This was a light duty with the switch knocked off. I asked the manager what he could do and he let me have it for $10. So $49 - $39. Not bad for a disposable. The switch was a $1.39 - shipping was $8 so I've got $20 in it.Con Fuse!
Miller Dynasty 350
Millermatic 350P
-Spoolmatic 30A
Hypertherm PowerMax 1000G3
-RyanCon Fuse!
Miller Dynasty 350
Millermatic 350P
-Spoolmatic 30A
I have used Dewalt, Makita,and have 3 Bosch's now. They are all comparable and like ace said you need to uof them as consumables when they die go find the one you can get the best deal on at the time. Happy Grinding!mm251 w/ 30amp spool gun
diversion 165
mm140
Hypertherm powermax 45
