i know makes models and all has been discussed many times but i can't find particulars on the one i am thinking of buying. Does anyone have experience with the Radnor 54VI Select auto dark. I'm looking at buying it from our local air gas dealer for $270. it has i believe a 4.5 by 3.5 window (which would be great for my bi-focals) with 4 sensors and solar powered with no on off switch to deal with. external control knobs. I have no experience with Radnor hoods at all. Any input would be greatly welcomed. thanks.
Radnor Helmet Question
miller 225 bobcat
miller aead200le (with miller hf tig trailer mounted)
mm175, mm211, TA181i
mm252 w/30a spool gun
precision tig 225
hobart stickmate LX ac/dc
Speedglas 9100X & XX / Miller Digital Elite
hypertherm 380 & cutmaster 52
victor journeyman & super range
ridgid chop saw, kalamazoo band saw
steel max and evolution carbide saws
6 4.5" & a 20lb 9" rockwell grinders
case 580 backhoe (for what i can"t lift)
if first you don't succeed
trash the b#####dTags: None
I'm looking for a second helmet myself.
Choices between Miller and Optrel. Both will run about $300 depending on where I buy it and precisely which model.
I will say, that with autodark helmets the window size is less important. On the passive helmets, you need to flip down the helmet, and then in total darkness, hope everything lines up when you strike the arc. With the auto-dark you line things up in advance, makes it easy.
And quite frankly, there isn't really that much you can see.
So...
Miller Elite - good helmet but sometimes goes dark at funny times when outdoors.
Miller Digital Elite - has magnetic sensor so should be better outdoors, but big negative for me is the manual on. I'm the guy that leaves gas bottles open all the time, you think I'll remember turning on the helmet? yeah, me nether.
Miller Titanium - not sure how they fit in but they have one model that has a big view and a flip up visor. I can't remember the last time I burned rod but if I did it every day that might be a deciding factor.
Optrel - Reputation for good color (not just green) and external controls (just remember which way to turn the knob) - on the negative, slightly smaller window, a bit tougher to find parts (that's what the internet is for).
Optrel and Miller Digital Elite have a cut mode with shade somewhere around 5. Right now I switch to a 'face mask'. Would be nice to use the same helmet, especially if its just a flick of the switch.
List price on the higher end stuff is about $400. Ebay pricing $240 + Internet pricing is competitive with Ebay. My LWS is about $75 more than Ebay. B&R seems to have a decent price on Optrel's.
There are a couple of auctions on Ebay for Miller Digital - note there is a difference between "Digital" and "Digital Elite" and the sellers sometimes get mixed up.Con Fuse!
Miller Dynasty 350
Millermatic 350P
-Spoolmatic 30A
Hypertherm PowerMax 1000G3
Originally posted by GTA/SPEC View Postcon_fuse9 -
magnetic sensor? Can you tell me more about this magnetic sensor and its benefit to welding outdoors?Miller Syncrowave 200
Homemade Water Cooler
130XP MIG
Spectrum 375
60 year old Logan Lathe
Select Machine and Tool Mill
Jackson EQC. ??
Originally posted by GTA/SPEC View PostIf you absolutly need an ADF, Save you money for a Jackson. You only have one pair of eyes.
Radnors are Chinese. Millers are South Korean. Jackson is made in the USA.
I know very little about them .
I'm using a Miller performance now .
.......... Norm
* Electromagnetic Arc Sensing eliminates: Sunlight interference - Outdoors, Low-Amperage Lens Opening - TIG, Lens Openings - Pipe/Curves, Obstructed Sensors - Hidden/Cavity Welds
Assuming its like my old helmet - when you do TIG with HF start, the HF is enough to trigger the helmet - basically you get no flash at all. One issue with Miller is this extra protection is only available in 'X-Mode' and is normally not the mode you weld with. There are pluses and minuses to that (IMHO).
I would think there are times when you want X-mode to work and some times when you don't. In the case of Miller, you must select it manually.
I guess if your in a tight spot and get flashed, you take the helmet off and select X-mode and put the helmet back on. (Assuming you can still read the mode screen)
Con Fuse!
Miller Dynasty 350
Millermatic 350P
-Spoolmatic 30A
