Customer called and asked for an estimate to fix an 8" inch crack in an old tractor motor. Lesson learned prior was never to give estimate over the phone. After taking broken pieces out of motor and checking the entire block, there was at least 36" inches of crack to repair plus installing a 6" inch by 9" inch plate. Those are the cylinders that you see.
Motor repair
motor repair
Originally posted by abprt View PostCustomer called and asked for an estimate to fix an 8" inch crack in an old tractor motor. Lesson learned prior was never to give estimate over the phone. After taking broken pieces out of motor and checking the entire block, there was at least 36" inches of crack to repair plus installing a 6" inch by 9" inch plate. Those are the cylinders that you see.
It was just water cooled turned air cooled that's all.MM200 w/spot controller and Spoolmatic 1
Syncrowave 180 SD
*HF-251D-1
*WC-1S & Spoolmatic 1
PakMaster 100XL
Marquette "Star Jet" 21-110
