30A spool gun
  • cruizer
    Could be though when the WC-24 dies it generally makes the 30A speed control to go full tilt. More probable is that you've lost the 24 Vac. Easily checked between pins "A" and pin "G" on your machine Amphenol., if its there then its likely your WC-24 or a loose or damaged control cable to your 30A gun.
  • vin-man welding
    ok, today i hooked my 30a to my trailblazer 302 for the first time in about 2 years and....nothing. it worked fine the last time i used it, but today nothing no wire feeding, just the gas coming out. can anyone help me? i have the 30a with the WC-24. i tryed every way there was to hook it up just to make sure i just didn't forgot how to hok it up. still nothing
    i had wire arc when i hooked it the stick setting but no wire feed. do you think the WC-24 died? or a problem with the gun?
  • captkipp
    30a
    I've used mine to run flux core and aluminum. Just clean out the liner and brush of the drive wheels. No worries. Pull the trigger and weld away.
  • metal-doctor
    Have had a 30A for 10 years now & no problems so far. We use it primarily for aluminum & think you would be happy with it. What machine are you attatching it to?
  • JSFAB
    A 30A spoolgun is simply a wire drive, it will drive any kind of wire you choose to put into it. No more, no less. I have run Steel, Aluminum, SS, Copper thru mine. Of course, one has to have the smarts to correctly set up wire speed and voltage in each case.
  • aametalmaster
    I don't use a 30a but i have a 3035 and run lots of steel thru it. But it did wear out the rollers so it wouldn't feed the alum anymore. So i ordered a new set and saved them for the alum only...Bob
  • wamcleod
    Thanks for the answers, I was pretty sure it would work now I know and got some useful tips to boot
    Bill
  • turk
    i just bought a spare liner for each kind of metal, and wipe the roller
  • cruizer
    Quite common, though you want to clean out your liner with compressed air before changing from steel to Aluminum. But thats about it.
  • wamcleod
    started a topic 30A spool gun
    30A spool gun
    I am looking at buying a miller 30A spoolmate gun (# 130831) and I am intending on using it primarily for Alum but would also like to use it for steel and stainless. I have not been able to get a clear answer from my local rep so i am asking if anybody is currently doing this and do i need to change rollers?
