Brand new dynasty 200 dx up in smoke
  • Brand new dynasty 200 dx up in smoke
    I am newly registered to this site, but had checked it out when trying to decide which tig to buy. I decided on a dynasty 200 dx over the lincoln invertec 200. I received my new welder on thursday and with a long weekend figured I would start getting used to the new machine. I got everything set up double checked everything plugged it in and nothing happened. After about 20 seconds smoke started slowly rolling out of the case and I heard a loud pop, turned off the machine killed the breaker and unplugged it. So much for using over the weekend.
    __________________
    Paul
    Lincoln Ranger 8
    Many many other tools cluttering up my garage
    I'm sorry to hear that. I guess you'll find out how good Miller's service is.
    Millermatic Passport Plus
    Millermatic 350P with Python
    XMT 304 /w S-64 feeder and 12VS
    Dynasty 300 DX
    Thermal Arc 400 MST
    Premier Power Welder for my trail junk.
      That is one reason why I bought the Miller, but I didn't expect it to go down as soon as it was plugged in. I will get to use it eventually. Then the fun will begin.
      __________________
      Paul
      Lincoln Ranger 8
        I also would be smoking if that happened to me
        Nick
        Miller 252 Mig
        Miller Cricket XL
        Millermatic 150 Mig
        Miller Syncrowave 200 Tig
        2-O/A outfits
        Jet Lathe and Mill
        Jet 7x12 horz/vert band saw
        DeWalt Multi Cutter metal saw
        Century 50 Amp Plasma Cutter
        Propane Forge
        60" X 60" router/plasma table
          SO.......How did you wire it? Or did you do the plug installation?
          Miller 30-A Spoolgun
          Miller WC-115-A
          Miller Spectrum 300
            That is such a bummer.
            When you get it up and running you are going to really enjoy it.
            Live Right Have Fun
            XMT350 CV/CC
            22A Feeder
            MM175
            TB302
            12vs Extreme
            Hypertherm PowerMax 1000
            20" x 40" CNC Mills (2)
            16" x 60" engine lathe
            65 Ton edwards iron worker
            3/16' x 24" power slip roll
            16' power feed mitering bandsaw
            and other fun toys
              I used a plug, into an outlet that was installed for my compressor by a master electrician and verified that all wire colors coordinated between the outlet and the plug going onto the welder. I took the plug off of my other tig, that worked fine in that outlet and was wired the same way. The compressor has been on that circuit for 3 years with out issue.
              __________________
              Paul
              Lincoln Ranger 8
                up in smoke
                Where did you buy the welder from? I just got mine Monday, according to most posts, this model is the top of the line, serious welder. To have one for home and hobby type stuff is pretty cool. I hope your supplier will just exchange it for a new one without sending for repairs. Fred
                  Yep that was unfortunate, the womping noise was the input Mod blowing up.
                  Before going further, I'd really suggest rechecking your input power, and power to the welder.
                  Electrician or not. Even they make numerous mistakes when hooking up Welders if they are un familiar with them. I get numerous calls from customers with new machines that either smoke, or don't work just after some "Electrician" has just wired them up.
                    I have to agree with Cruizer on this one. I'm much more inclined to suspect improper installation than a faulty machine. Not saying it can't happen, but it would be extremely rare.
                    Did the machine show any signs of damage in shipment?
                    If you received the machine on Thursday and "hooked it up", what was the response from your retailer on Friday? What did Miller Tech Support have to say?
                    I'm not saying this couldn't happen, just that the whole post by onefishnfool seems a little "fishy" to me.
                    He states that he "researched the machine" on this board prior to purchasing. Really. Why didn't he join at that time? Is he implying he got all his questions answered by using the "search" feature and didn't need to ask ANY questions?
                    Just seems a little strange to me that his first "course of action" would be to post on a board where he wasn't even a member. My first call would have been to the retailer and the second to Miller.
                    I'm definitely not saying that it's the case here, but I wouldn't put it past some of the "Chinese Importers" to post such a story so that they can say, "Well, it happens to Miller too. Check out this posting".
                    Hopefully, we'll get the whole story as time goes on. I'm sure, if there was a problem with the machine, Miller will make it right.
                    Edit. Is the Invertec 200 by Lincoln a new machine? I'm aware of an Invertec 205 but never heard of a 200. How much real research was done? Just another tidbit to make me question this post.
                    Syncrowave 250 DX Tigrunner
                    Miller MM 251 w/Q300 & 30A SG
                    Hobart HH187
                    Dialarc 250 AC/DC
                    Hypertherm PM 600 & 1250
                    Wilton 7"x12" bandsaw
                    More grinders than hands
                      Sounds like improper hook-up to me.
                      I agree, if it does turn out to be a problem with the machine and not with the hook-up. Miller will fix it. If it's the hook-up, you might be 'on your own'...
                      Millermatic175
                      MillermaticPassport/Q300
                      HTP MIG200
                      PowCon 300SM, MK Cobramatic
                      DialarcHF, Radiator-1
                      Hypertherm PowerMax 380
                      Purox oxy/ace
                      Jackson EQC
                      -F350 CrewCab 4x4
                      -LoadNGo utility bed
                      -Bobcat 250NT
                      -PassportPlus/Q300
                      -XMT304/Optima/Spoolmatic15A
                      -Suitcase8RC/Q400
                      -Suitcase12RC/Q300
                      -Smith oxy/propane
                      -Jackson EQC
                        It could just as easily be a faulty component, don't jump to conclusions. I was in his shoes with a VFD recently, the manufacture tried to claim faulty hookup but still sent me a refund, I purchased a replacement hooked it up exactly like the bad unit which smoked up like this welder and have been rewarded with no problems what so ever. Regardless before I hooked up the new unit I made absolutely sure there were no problems with the power, amps, voltage, ect. In the vfd it was a bad MOV "metal oxide varesistor" a surge suppressor.
                        Good luck, you should be fine if you in fact did not fry the thing yourself if so you will be sure you don't next time.
                          Verify your input wiring, if it's wrong correct it. Without explaining what happened to it, have it repaired at your local Miller service depot. I assure you they won't care much as to what caused the problem. Most of them never tend to discover the route cause as Miller only allows so much time to find & R/R the damaged component.
                            burned dynasty
                            Just wondering how many amp service the plug was?
                              I don't think this matter much as the voltage.
                              Dynasty 300 DX
                              Thermal Arc 400 MST
