Its not a welding related problem but it did happen on my welding rig. Went to fill up the windshield washer reservoir and quickly grabbed the right container but forgot that I had used it recently to hold some extra motor oil.(long story) So before I could say,"Way to go stupid", I had poured oil into the windshield reservoir. I've tried pulling the reservoir out but its a Dodge and its in there good. So, any suggestions? Is there a product that will break down the remaining oil film after I drain it?
Motor oil & Windshield water don't mix.
oil and water in reservoir
Try dish soap in your windshield wiper reservoir.Trailblazer 325 EFI
SVI 300i cvcc
Mig 4HD & Mig 2E wire feeders
Ultra-Pulse 300i Pendant
EAS-IV Electronic Arc Starter and Plumbing Box
Powermax1000 G3 Series
AC-225 Arc Welder
Yup theres a product.....
I would remove the tank, flush it with denatured alchol, then wash it with dawn liquid detergent. U might just get away with the dawn, remove the tank, pour in some dawn, then use the hottest water u can get from the tap, shake it up, drain repeat. When oil gets in the coolant system in gas/diesel engines I use dawn to clean them out, work awesome.
KevinLincoln ranger 305g x2
Ln25
Miller spectrum 625
Miller 30a spoolgun
Wc115a
Lincoln 210mp
F550 imt service truck
Right on guys! I knew I could count on forum members to come up with some good suggestions. In fact, isn't that what the clean-up crews use on the waterfoul after an oilspill? Although I'm not looking for something gentle for my feathers, dish detergent will likely do. And the weather has warmed up some, so its a good time to get at it. Thanks again! Bob.
Dish soap should work great. Also a product that's on most supermarket shelves the we use to use in the oxygen and diving business called "Simple Green" will do the trick. ZEP company makes a great degreaser as well. Try takin off the feed hose to the pump to avoid getting oil up in the pump. But if there was water in the reservoir then the oil will sit on top of this water and you should be able to extract it from the tank. There is a paper towel type of material we commonly call "diapers" that are specifically made to suck up the oil and leave the water. They also use these for oil spills and associated clean up. You can get them at NAPA and other auto stores. Good luck. This should go pretty well I think. Unlike me who dumped about 17 gallons of 91 octane into a diesel tank one day....Mustangs Forever!
Miller equipment.
Originally posted by captkipp View PostDish soap should work great. Also a product that's on most supermarket shelves the we use to use in the oxygen and diving business called "Simple Green" will do the trick. ZEP company makes a great degreaser as well. Try takin off the feed hose to the pump to avoid getting oil up in the pump. But if there was water in the reservoir then the oil will sit on top of this water and you should be able to extract it from the tank. There is a paper towel type of material we commonly call "diapers" that are specifically made to suck up the oil and leave the water. They also use these for oil spills and associated clean up. You can get them at NAPA and other auto stores. Good luck. This should go pretty well I think. Unlike me who dumped about 17 gallons of 91 octane into a diesel tank one day....
Originally posted by Cornerstone View PostIts not a welding related problem but it did happen on my welding rig. Went to fill up the windshield washer reservoir and quickly grabbed the right container but forgot that I had used it recently to hold some extra motor oil.(long story) So before I could say,"Way to go stupid", I had poured oil into the windshield reservoir. I've tried pulling the reservoir out but its a Dodge and its in there good. So, any suggestions? Is there a product that will break down the remaining oil film after I drain it?
Oh, you just got demoted from Parade mechanic.'08 F-350
Vantage 400
SA-250
SA-200
Invertec V350Pro
Invertec V205T-AC/DC
Miller 12VS suitcase
Miller spectrum 2050
Pipe beveler's
Track torch
Originally posted by Cornerstone View PostOh, you just gotta be a welder!'08 F-350
Vantage 400
SA-250
SA-200
Invertec V350Pro
Pipe beveler's
Track torch
Originally posted by Rig Hand View PostHow does that song go "Well he use to be a pretty nice feller, but now, he's a welder" LOL
Which reminds me of a stunt I pulled, recently I was preparing my chainsaw for a project, proceeded to fill the oil reservoir w/the chain oil, noticed it took quiet a bit of oil, the reason.... was the fuel tank. Some days it just doesn't pay to chew through the restraints.
Have a good day all
L*S
Goof Ups
When I was in my Teens, I put Tranny fluid in the Brake Reservoir
long time ago !
............ Norm
Originally posted by nfinch86 View PostWhen I was in my Teens, I put Tranny fluid in the Brake Reservoir
long time ago !
............ NormBobcat 225NT
Cutmaster 52
Lincoln Weld-Pak 100 buzz box
Caterpillar TH63
'07 Kawasaki ZZR600
