Tig welding pop cans
    i just cleaned them up with a stainless wire brush then welded. im not gonna say its easy but not really that hard either. i think mainly just heat control and knowing your machine. advice i could would be if you have hf intensity adjustment turn it down and have a good ground. 1/16 tungsten and 1/16 or smaller filler would pry make it easier and make a smaller weld. but you dont really need anything special. heres a pic i did of one with 3/32 tungsten ans 3/32 filler rod. i think it was around 35-40 amps on a synchrowave 350lx
    spence648
    Senior Member
      Originally posted by spence648 View Post
      i just cleaned them up with a stainless wire brush then welded. im not gonna say its easy but not really that hard either. i think mainly just heat control and knowing your machine. advice i could would be if you have hf intensity adjustment turn it down and have a good ground. 1/16 tungsten and 1/16 or smaller filler would pry make it easier and make a smaller weld. but you dont really need anything special. heres a pic i did of one with 3/32 tungsten ans 3/32 filler rod. i think it was around 35-40 amps on a synchrowave 35olx[/IMG]
      Your pic link didnt work out so well. I have a Syncrowave 200.
      Miller Trailblazer 302
      Miller Passport Plus
      Miller Spoolmate 100
      Milwaukee 4 1/2" Angle Grinder
      Milwaukee Sawzall
      Miller Elite Inferno Hood
      Miller Diversion 180
      Miller Digital Elite Vintage Hood
      Miller Camo Digital Elite Hood
        sorry took me awhile to figure it out lol.
          I like TIG welding but have never really seen the need to weld soda cans. It seems more like a parlor trick than anything useful. I guess the question would be if anyone has ever made anything useful out of them.
            Looks pretty good.
            Milwaukee Sawzall
            • #21
              It is more of a "parlor trick". What use could you actually get out of welding pop cans together? Other then showing off what use could you get out of welding aluminum foil? Thats all it is. Just something to show off.
              Milwaukee Sawzall
              • #22
                I still think it's cool though whether there's a use for it or not.
                Milwaukee Sawzall
                • #23
                  pry not a need to weld up cans, but i disagree it is usefull. it can make you a better welder. if a person trys to weld cans together and cant do it. he or she is going to gain by keep trying till they get it down. once you are able to do it consistantly you just learned how to weld on thinner matieral than before.
                  • #24
                    I totally agree with you & whats cheaper to practice tig welding aluminum on than pop cans.
                    Milwaukee Sawzall
                    • #25
                      Originally posted by J C View Post
                      What kind of aluminum are pop cans are made of? Do they require any prep work or can you just start welding them? Please make your suggestions. Feel fre to post pics of any you've done. Oh yeah I was thinking of welding the bottoms together.
                      To answer your first question. The top of pop cans is made of 5182 the rest is 3004. Check out the following link for more information:
                      http://machinedesign.com/article/alu...velopment-1209
                      Smith Oxyacetylene Torch
                      Miller Dynasty 200DX
                      Lincoln SP-250 MIG Welder
                      Lincoln LE 31 MP
                      Lincoln 210 MP
                      Clausing/Colchester 15" Lathe
                      16" DoAll Saw
                      15" Drill Press
                      20 Ton Arbor Press
                      Bridgeport
                      • #26
                        Alright. Thanks for the info.
                        Milwaukee Sawzall
                        • #27
                          beer cans are better
                          drink 2 try to weld. drink 2 more and try again. keep repeating, something good will happen eventually.
                          • #28
                            After 6 or 7 rounds of this I know I was pretty good. Had trouble the following morning trying to remember where I put the TIG machine though.
                            Mustangs Forever!
                            Miller equipment.
                            • #29
                              I had a friend who drank enough beer that if he were able to have found someone to weld them together he could have built a mansion out of empty beer cans.
                              Miller 340A/BP
                              Victor O/A torches
                              Lincoln SP125
                              Too many other tools to list
                              03 Ram 1500
                              78 GS1000
                              82 GL1100 Interstate
                              • #30
                                Hey there guys, stumbled across this forum and thought i would have a crack at welding cans and some foil.
                                Cheers and beers
                                Breno
