Tig welding pop cans
  • Tig welding pop cans
    What kind of aluminum are pop cans are made of? Do they require any prep work or can you just start welding them? Please make your suggestions. Feel fre to post pics of any you've done. Oh yeah I was thinking of welding the bottoms together.
    Miller Trailblazer 302
    Miller Passport Plus
    Miller Spoolmate 100
    Milwaukee 4 1/2" Angle Grinder
    Milwaukee Sawzall
    Miller Elite Inferno Hood
    Miller Diversion 180
    Miller Digital Elite Vintage Hood
    Miller Camo Digital Elite Hood
    Hope you are real good the bottoms aren't much thicker...Bob
      Check out the thread Passenger started and look at the photos of the pop cans and razor blades.
      http://www.millerwelds.com/resources...ad.php?t=18483
      I would suggest you PM him for some guidance...
        One word of caution on welding pop or beer cans. They both have an epoxy resin type coating on the insides and outside. The inside to protect the contents from picking up metallic taste. And the outside to protect the screen printing ink with the logo's etc.
        So you might want not to breath the fumes coming off them.
        You want to do some thing hard do like Ron Covell and TIG weld two pieces of aluminum kitchen foil. Now that really blows peoples minds, Of course there is a trick and it is two heat sink strips holding the two sections together with about an inch above the bars of metal. Torch along the top of the bars, burning off the section above.
        Lowest amps and move fast no filler rod required. He shows it in his TIG welding video they sell on this site.
        glen, If your not on the edge, your wasting space
          The bottom ring has a coating too, to aid in movement in the factory.
          Thats what I do for a living. 6,000,000 cans in 24 hrs. 24hrs a day 7 days a week. there is a fair amount of aluminum in the chime(bottom) of the can.
          MM 211 W/ Spoolgun
          Diversion 180
          Spectrum 375 X-TREME
          Portable Victor O/A
          Palmgren Bench Drill Press
          14" Evolution Dry Saw
          IR 60 Gal. 3 HP Compressor
          Speedglas 9100x
          My Brain
            If you take a red scotch brite pad, you can get the coating off the outside, and if you have good enough amperage control, you can weld along the side of it. It isnt the best weld, but it does impress people.
            It might be in the thread that was already posted, but someone welded a scrap piece of AL to the side of a can...THAT impressed the **** out of me.
            Precision is only as important as the project...if you're building a rocket ship...1/64" would matter. If you're building a sledgehammer...an 1/8" probably wont.
              What kind of aluminum are they made out of?
              Milwaukee Sawzall
                I'm not exactly sure, 3000 series i think. It comes in 20,000 lb rolls
                MM 211 W/ Spoolgun
                Diversion 180
                Portable Victor O/A
                Speedglas 9100x
                My Brain
                  Thanks for the good info guys.
                  Milwaukee Sawzall
                    Spamming are we Hussy ?
                    Hussy lay off the bs spam. Its getting old and maybe soon you'll get the boot. You seem to be spamming everywhere these days.Moderators take note.
                    Bernard 3500ss water-cooler
                    Rockwell vertical mill
                    Beverly Shear B-3
                    Beverly Shear JR
                    Home-made English wheel
                    Milwaukee Porta-band
                    " Sawz-all
                    Tennsmith 36" stomp shear
                    Powcon 300st
                      I agree he didn't really say anything pertaining to the original post nor any posts made after that.
                      Welding the bottoms of pop cans together takes an experienced TIG welder with lots of aluminum experience. I've been welding for 35 years now and don't know if I could do such a thing as most of the materials I weld on are 1/16 and thicker. If I were to try though I'd probably use an .040 Ceriated tungsten and .030 filler wire. I'm not sure my 340 A/BP will go down that low in amps to try it and I don't have access to an inverter machine. In fact I've yet to weld with an inverter.
                      Miller 340A/BP
                      Victor O/A torches
                      Lincoln SP125
                      Too many other tools to list
                      03 Ram 1500
                      78 GS1000
                      82 GL1100 Interstate
                        Welding the bottoms of cans is faily easy. If you can weld to the sides.... thats impressive.
                        Just use the same practices that you would use on any critical weldment. Theres no tricks to welding the bottoms.
                          Are you using an inverter or transformer welder? I have an old transformer welder from the early 70's and I don't think my amperage will go that low. I may order some .040 tungstens and give it a try. I know a member here who can weld gum wrappers (back in the day when they had thin aluminum foil on them).
                          Miller 340A/BP
                          Victor O/A torches
                          Lincoln SP125
                          03 Ram 1500
                          78 GS1000
                            No one's ever offered me a red cent for welding pop cans together, so I don't do it.
                            Course, if there's a market for this, I'll have to look into it.
                            Syncrowave 250 DX Tigrunner
                            Miller MM 251 w/Q300 & 30A SG
                            Hobart HH187
                            Dialarc 250 AC/DC
                            Hypertherm PM 600 & 1250
                            Wilton 7"x12" bandsaw
                            More grinders than hands
                              Hey Sundown
                              How about you weld up a bunch and I'll give you a cent or maybe two for each. Then I can set them around my shop and tell all the boys, see, I can weld pop cans and you can at least make something. Since I haven't had any success after about half way around, I think it is out of my league.
                              Dynasty 350 - My New Baby
                              Millermatic 210 Mig with Spoolmate 3035
                              Miller Thunderbolt XL 225/150 AC/DC Stick Welder
                              Miller Specturm 625 Plasma Cutter
                              Speedglas 9100 auto dark helmet
                              Jackson auto dark helmet
                              18.5 CFM Eagle Compressor
                              Oxy/Act
                              Horizontal Band Saw
                              Dewalt 14" Chop Saw
                              7 1/2 Dewalt Angle Grinder
                              4 - 4 1/2" Sears Angle Grinders
                              1 - 4" Makita Angle Grinder
                              2 - IR Die Grinders
                              All of which my wife says will be a "he$$ of a garage sale"
