I would like to find a small, reasonably transportable MIG machine to use for light work that I would most likely keep a roll of .023 hardwire in, but would like to be able to use any of the smaller cored stuff and maybe even do some thin aluminum with it, too. My big MIG machine isn't really useful with a spool gun so maybe it would be nice to have a smaller machine that could have a spool rig hooked up to it with MINIMUM or NO fuss. I do have 220 (single phase) available, but is there a good little 110v wire shooter out there?
I currently have a Millermatic 250X for MIG work that usually has a roll of .035ER70S-6 in it, but sometimes (pretty rarely) I use .045 cored for higher deposit chores. The 250DX does great spray with 86/14 and I like the machine a lot. Also in the shop is a Miller Dial Arc 250 AC/DC for stick work. Both are using single phase 220v and the old Dialarc weighs about as much as my pickup truck, so it isn't really too portable. Same thing for the 250X, though it only weighs maybe half as much as my truck. I will probably keep both of these machines until I learn to be decent TIG welder and then may try to find something that will do both TIG and stick as is pretty common from what I see.
So anyway, what machine(s) would you all suggest to sort of fill in the "bottom end" of the welding range without having to spend a fortune (think maybe...Craigslist!)? By the way, I currently have a little *incoln weldpak 100 piece of **** that does nothing for me but give me headaches. I bought it as a first welder before I knew any better and have done nothing but regret it as it seems to have too much plastic in it and NEVER seems to just feed nice and consistent! I would like to make the shop all "BLUE" and get rid of that little bugger! The ONLY advantage it has that I can see is that it uses 110v.
I am open to any suggestions from people that have had experience with the smaller MIG stuff!
Thanks!
Don J
Reno,NV
Thanks!
Don J
Reno,NV
