resources for job estimation?
  • resources for job estimation?
    Hello all,
    I've been searching for literature on standard costs for estimating bids on welding/fabrication jobs. I found very little. I'm developing my on reference guide based on actual job production but this is an on going record. Can anyone refer me to an existing guide/calculator?
    Miller TrailBlazer 251NT
    Miller HF-250-1
    Miller Maxstar 150slt
    Miller ft peddles and thumb wheels
    Miller MM 212
    Lincoln power mig180c (two of)
    MM 252
    Miller Elite Dig
    Miller Pro-Hobby
    I don't know of any guides. I just figure each job individually. I figure up the materials costs, add in any unusual consumables costs (special electrodes or gas, cutting drilling painting or bonding stuff, etc needed to do the particular job) then estimate the labor time and come up with a total. For fence and railing, you can go by dollars per foot, anywhere from $50 to $150 per foot, depending on complexity/cost of the design/materials and difficulty/location of the project. Basic tube steel and pickets is cheaper per foot than lots of scroll work, stainless, or aluminum.
    Millermatic175
    MillermaticPassport/Q300
    HTP MIG200
    PowCon 300SM, MK Cobramatic
    DialarcHF, Radiator-1
    Hypertherm PowerMax 380
    Purox oxy/ace
    Jackson EQC
    -F350 CrewCab 4x4
    -LoadNGo utility bed
    -Bobcat 250NT
    -PassportPlus/Q300
    -XMT304/Optima/Spoolmatic15A
    -Suitcase8RC/Q400
    -Suitcase12RC/Q300
    -Smith oxy/propane
    -Jackson EQC
      http://www.esabna.com/EUWeb/AWTC/Lesson9_1.htm
      You can make an Excel worksheet template to calculate all of the costs.
      Ed Conley
      MM252
      MM211
      Passport Plus w/Spool Gun
      TA185
      Miller 125c Plasma 120v
      O/A set
      SO 2020 Bender
      You can call me Bacchus
        Thanks!
        Thank you Broccoli 1,
        That link is a great resource!
        Miller HF-250-1
        Miller MM 212
        MM 252
        Miller Elite Dig
        Miller Pro-Hobby
          what kind of job are you bidding on. or do you want to find a program for future jobs?
            Apologizes for the delayed response.
            Currently I have an eclectic array of jobs. I do fairly well in estimating actual fab time and material costs. Have fell short in allowing design and logistics time involved. What I need is some sort of base line in calculating the cost of consumables. For ex..power consumption, filler wire/rod, grinding discs, shield gases, oxy/act, plasma usage cost, allowance for over head. The majority of shop work I do is mig but includes some stainless tig, some carbon to stainless(309L). I also do some site jobs, portable. Recently I've had small but meticulous jobs, requiring concept designs of fixtures and process to achieve desired end results. I'm shooting in the dark trying to allow for cost variables.
            Miller HF-250-1
            Miller MM 212
            MM 252
            Miller Elite Dig
            Miller Pro-Hobby
              Simple project estimate
              Unless there are specialised equipment and consumables involved, I use the rule of "3". When looking at what Framing Carpenters charge by the square foot to just do the basic framing, this rule of 3 is pretty much on par.
              Say that you are making simple frames or carts out of angle iron or channel. You purchase $100 in angle and channel iron. Then the total job is charged out at $300. This covers a saw blade, grinding wheel ... If said customer wants to supply the materials, then I would call the local steel supplier for the price of material (and using this example of they quoted me $100 worth of steel) then charge $200 for my fabrication. If it gets too complicated or say there is stainless steel pipe that needs to be purged, special jigs and fixtures to be made, then it becomes complicated and I would have to go by Time and material.
              On simple aluminum fab such as in the first example (the last time I priced Aluminum, it was 4 times the price of steel), I might consider a 1 to 1 on the bid.
              I worked at a shop once, where most projects were bid by the ton. If I remember correctly it came out to 87 cents a pound...
                Hmmmmm.....
                "Have fell short in allowing design and logistics time involved."
                This is the BIG problem when bidding a job from "Bar Napkin Blueprints".
                If you are going to be a respectable business, then one must charge an appropriate fee for any and ALL services. Bid in an acceptable "engineering/drafting fee"
