There seems to be a lot of misunderstandings here, and most people have absolutely no idea ......
Essentially, a Charpy test measures the "toughness" of a weld.
Proceedure for the test, do the weld, cut the sample to specified size, put a notch in the weld. Bring it to the temperature you want to test at, clamp it in the apparatus.
A pendulum is used, again, standard, weight and arc. Bring it up to height, release it, it strikes the sample. The sample will always break, that's not important. What is important is how far the pendulum swings up afterwards, doing the measurements and arithmetic one can determine exactly how much energy it took to break the sample, measured in ft./lbs.
Not the same as a tensile test. 70,000 PSI pull is still 70,000 pounds pull, the charpy test measures the resistance to cracking and failure, and the ability to take stresses, from a sudden impact.
Generally, a more ductile weld will absorb more energy, before giving way, than a more brittle weld material.
As I understand it, ALL T-8 wires need to have charpy tests, ALL Low-hydrogen rods need charpy tests, to meet AWS specs. For the most part, also ALL dual-shield wires (gas-shielded, flux cored) also require charpy tests. NO T-11 wires need to have charpy tests, nor GS or G wires. In fact, it's just not done, if a T-11 wire could have a charpy test, it will become a T-8 wire, right???
This started becoming really important here in California, only after the Northridge earthquake. Far too many buildings, were severely damaged, or just fell down, due to the use of T-11 wires. They are still used many places across the country, just not where seismic rules are in place.
Understand, I am far from an expert at any of this, I am not an engineer, if anybody has any better explanations, please post up.
