Spectrum 375 X-Treme with an Ingersoll 4.4 cfm
    For the extra money get the bigger one. You won't be sorry.
    MM250
    Trailblazer 250g
    22a feeder
    Lincoln ac/dc 225
    MM200 black face
    Lown 1/8x 36" power roller
    Arco roto-phase model M
    Vectrax 7x12 band saw
    Miller spectrum 875
    30a spoolgun w/wc-24
    RCCS-14
      I'm currently looking at a Campbell Hausfeld #VT6275 which is at Lowes for $399, 10.2 scfm @ 90 psi & also a Campbell Hausfeld #VT6355 which is at Tractor Supply for $399, 10.2 scfm @ 90 psi. Tractor Supply currently has a 10% off coupon till 11/22. I can't seem to find the difference between the two models though. The pics look the same. I guess I have to go see them in person.
      MM250
      Trailblazer 250g
      22a feeder
      Lincoln ac/dc 225
      MM200 black face
      Miller spectrum 875
      RCCS-14
        Also Home Depot has a very similar one at $399 with the same scfm but again a different #. It is # VT6314 but is labeled "Husky" which is a house brand. But the # says it is a Campbell Hausfeld.
        MM250
        Trailblazer 250g
        22a feeder
        Lincoln ac/dc 225
        MM200 black face
        Miller spectrum 875
        RCCS-14
          Compressor Requirements
          As a general rule, when determining compressor size, multiply the plasma's CFM input requirements by 1 1/2. It's not so much the PSI the compressor creates, but the amount of CFM delivery volume. Anything smaller will provide unsatisfactory results.
          Dave
          "Bonne journe'e mes amis"
            For some reason mine seems to work fine. Guess I'm just lucky.
            Larry
            "I feel for the man who can only spell a word one way"......Mark Twain
            Lincoln AC225-S (OLD/Copper Wound)
            Lincoln Weldpac 100
            Miller Matic 180 (auto set)
            Miller Spool gun 100
            Miller Spectrum 375 Extreme
            Victor Super Range II
            • #21
              Just got back from Tractor Supply. While I was there I checked out the compressors in person. After internet shopping I was mostly sold on the Campbell Hausfeld 60 gallon upright unit for $399 but after seeing the CH sitting next to an IR 60 gallon ($599) in person I would go with the IR. Everything from the motor, compressor head & the fittings seems way better quality. Even when you tap on the tank there is a noticable difference in thickness. I will definitely spend the extra $200 when I buy one in the near future.
              MM250
              Trailblazer 250g
              22a feeder
              Lincoln ac/dc 225
              MM200 black face
              Miller spectrum 875
              RCCS-14
