electrical question
  • electrical question
    I need to run 4 #10 wires & 2 #12 wires. The run is 40' or less. What is the minimum conduit size? Two(2) 30 amp circuits with grounds.
    MM250
    Trailblazer 250g
    22a feeder
    Lincoln ac/dc 225
    MM200 black face
    Lown 1/8x 36" power roller
    Arco roto-phase model M
    Vectrax 7x12 band saw
    Miller spectrum 875
    30a spoolgun w/wc-24
    RCCS-14
    MMW; For where and for what, are you having to run theses cables ?
    .............. Norm :
      Depends on the type of Conduit yer using.
      I think you can get 5 #10 in 1/2" EMT but only 3 in RNC (PVC)
      If you go with 3/4" yer good for either one.
      I'm sure a Sparky will provide an answer.
      Ed Conley
      MM252
      MM211
      Passport Plus w/Spool Gun
      TA185
      Miller 125c Plasma 120v
      O/A set
      SO 2020 Bender
      You can call me Bacchus
        Norm,
        it is not cable
        Ed Conley
        MM252
        MM211
        TA185
        O/A set
        SO 2020 Bender
          Wire !!
          Originally posted by Broccoli1 View Post
          Norm,
          it is not cable
          OK Ed; Picky, Picky !! Then where are you puttin' said WIRE !!:
          ............... Norm
            inna Conduit
            Ed Conley
            MM252
            MM211
            TA185
            O/A set
            SO 2020 Bender
              Norm-- Indoors, in my shop. One circuit will be to power a phase converter & the other circuit along with the third leg off the phase converter will be to a 3-phase outlet. Just following the manufacturer's wiring diagram but wanted to make sure it is code with conduit size. I was thinking of using 3/4 emt but wanted someone who knows to double check my thoughts.
              MM250
              Trailblazer 250g
              22a feeder
              Lincoln ac/dc 225
              MM200 black face
              Miller spectrum 875
              RCCS-14
                use 3/4
                Use 3/4 anything smaller and pulling wires IS A PITA.
                Kevin
                Lincoln ranger 305g x2
                Ln25
                Miller spectrum 625
                Miller 30a spoolgun
                Wc115a
                Lincoln 210mp
                F550 imt service truck
                  inna Conduit
                  Ed; You one Funny Feller !!!
                  .............. Norm
                    MMW; I can't help on the 3 - Phase business !
                    What ya plannin' on runnin' anway ?
                    .............. Norm
                      What difference does it make, Norm??? The man stated the size of the wire, the number of wires, wants to know what conduit to use.
                      Does knowing what he's gonna do with it, make a difference in your answer??? IF, of course, you DO have an answer????
                        3/4 should be sufficient, but,,,, it could depend on what he is running, it may be a valid question. Some scenarios might only allow for 3 current carry conductors depending on load. If one isn't smoking on more than 30A on the 10's and 20 on the 12's its probably good to go. Kind of rudimentary explanation.
                          Conduit size
                          Use 3/4". You can down size one wire gauge size for the Neutral and one more for the Ground. In other words if you're running # 10 for the 3 legs of the 3 phase you can use a #14 for the ground. If you run a #8 for a single phase you could use a #10 for the neutral (usually a white wire) and a #12 for the ground (usually a green wire).
                          Dont forget to color code you three legs of the three phase. Red, black and orange are commom colors.
                          If you need help, don't hesitate to contact a qualified electrician. And buy a bottle of wire pulling lubricant. You will thank yourself for this extra purchase.
                          Using non metalic pvc conduit is easier than having to bend the emt. And you will save the bender cost. But you need to check codes first to see what conduit is allowed. Providing of course you care about that.
                          Mustangs Forever!
                          Miller equipment.
                            Kevin
                            Ditto that, As that conduit fills up 1/2'' will be no fun to get all the wires through,besides with 3/4'' if you want to add anything later it will be easier.Mike
                              1/2" EMT conduit is adequate. Now let me explain.
                              NEC 328.52 Number of Conductors: The number of conductors shall not exceed that permitted by the percentage fill specified in Table 1, Chapter 9.
                              NEC allows 40% of the cross sectional area of the conduit to be filled with wires (when running more than 2 wires, according to table 1 chapter 9).
                              The cross sectional area of 1/2" EMT conduit (which is actually .622" ID) is pi*.311^2 or .304 sq in, of which only 40% is allowed to be filled, or .122 sq in.
                              The cross sectional area for #10 THHN is .0211 sq in and for #12 it is .0133 sq in.
                              So the total cross sectional area of wires are 4*.0211 +2*.0133=.111 sq inches, or 36.5% of the cross sectional area.
                              No sweat pulling wires through a conduit that is less than 40% filled.
                              So you can use any size EMT you want. But if you use 1/2, consider it filled to capacity.
