Aeronca Champ ? Aerometalworker ?
  • Aeronca Champ ? Aerometalworker ?
    I've meat a guy that wants me to weld/fab some seats for his 1947 Aeronca Champ. He's gonna provide all material cut , bent , and prepped all I have to do is fit/tack and weld. Material is .035 4130 chromoly and question is what would you use to weld it with ? Tig of course.
    Bernard 3500ss water-cooler
    Rockwell vertical mill
    Beverly Shear B-3
    Beverly Shear JR
    Home-made English wheel
    Milwaukee Porta-band
    " Sawz-all
    Tennsmith 36" stomp shear
    Powcon 300st
    Go Here
    Jerry in Anchorage
      Hey Showdog, Sorry I have been out of the internet loop lately, just too much going on. You probably have the seats done by now though For something like a seat I would have no issues using the Tig process.
      Miller Dynasty 300DX
      Miller Dynasty 200DX
      Miller Spectrum 375 extreme
      Miller Millermatic Passport
      Miller Spot Welder
      Motor-Guard stud welder
        Dunno if you have found an answer yet or not, but the aerospace guys I know recomend ER80s-2 or ER80s-6 filler rod. For .030 tubing probably 1/16" electrode, 40 to 60 amps, .060 filler rod. Alternately you could also look up a company called Weld Mode-- they have a filler called weldmode 880 that the performance mountain bike guys love for doin 4130 bike frames. I can tell you it welds awesome, can't however tell you about possible FAA certs. for that particular consumable. Best of luck,
        WH
        Big Blue 400D
        Trailblazer 302
        Miller S-32 suitcase
        12VS suitcase
        Lincoln LN-7 (BIG suitcase)
        Victor torches
        Lincoln 350MP with 35' push-pull gun
        Lincoln PrecisionTIG 375
        Spectrum 1000 plasma cutter
          WH
          Who might they be?
          Miller Spot Welder
            Weldmold
            I use it for cro-moly and high end bicycle tubing, it flows really well. for welding the .035. You might wish you had some .045 filler, I use mostly .035 wire for tig. I don't know if you can order off of the website online , In the past , I have just called them. Look around the site a little, if you make an order you might as well pick up some other hard to find filler. Good luck!
            Miller 251
            Miller Trailblazer 280nt
            Miller Maxstar 200dx
            Lincoln Squarewave 185
            Acme 20kva spotwelder
            Hobart buzzbox
            Thermal Dynamics plasma cutter
              An Aeronca Champ is light sport and doesn't come under nearly as much FAA grief as a recreational aircraft does.
              That said regular old ER70S-6 has worked well for me. But there are better choices
              South bend lathe 10LX40
              K.O. Lee surface grinder 6X18
              Auto shades are for rookies
              www.KLStottlemyer.com
                Its only light sport if its registered as such, otherwise it falls under the standard regulations for certified aircraft.
                Miller Spot Welder
                  Sling Seat??
                  Years ago I had an Aeronca "K" ....... and it had a "Sling Seat" which consisted of bolted crossbars and a canvas sling hung between them much like a simple sling beach chair.... thought that the early Champ had a similar arrangement..... the "K" was a side by side like a Chief..... not a tandem like the Champ.... just wondering what might need to be welded on this...
                  thanks
                  Heiti
                  BTW.... a 47 Champ would have originally been all gas welded using Oxy-Acet...
                    I don't think a 47 Aeronca Champ can ever have a E-LSA or S-LSA Airworthiness Certificate since it was certainly issued a Standard Airworthiness Certificate.
                      Actually yes it can. Basicly you give up the SAC and register as an LSA. The means though that the aircraft can only be operated in the LSA category and going back to SAC will be interesting unless flawless records are kept and the aircraft is kept in a configuration thats still approved for SAC. I have a feeling whats going to happen quite often is that once an aircraft gets registered under LSA, that the owner will start doing modifications, alterations, and maintanence that will make getting the aircraft back into SAC a big headache in the future.
                      Miller Spot Welder
                        I'd like to see how that works. Do you have to know the right people at FSDO? Seems to fly in the face (no pun intended) of the FAR 21.191(i)(1) and 21.190(b)(2).
                        Sec. 21.190
                        Issue of a special airworthiness certificate for a light-sport category aircraft.
                        (b) Eligibility. To be eligible for a special airworthiness certificate in the light-sport category:
                        (2) The aircraft must not have been previously issued a standard, primary, restricted, limited, or provisional airworthiness certificate, or an equivalent airworthiness certificate issued by a foreign civil aviation authority.
                        Sec. 21.191
                        Experimental certificates.
                        Experimental certificates are issued for the following purposes:
                        (i) Operating light-sport aircraft. Operating a light-sport aircraft that-
                        (1) Has not been issued a U.S. or foreign airworthiness certificate and does not meet the provisions of §103.1 of this chapter. An experimental certificate will not be issued under this paragraph for these aircraft after January 31, 2008;
                        I'd really like to know if there is a way around this!
                          Simple as it may seem, it requires removal of the original data plaque, and basicly a new manufacturer, serial number, etc being attached to it. You can call it a replica. The original SAC follows the data plaque, not the physical structure. This is where its going to get sticky to go BACK to SAC, and unless your close with your local field office, might not be possible at all. That was done mostly to discourage all the old anique aircraft from being turned into LSA versions and to more or less preserve them as I understand it.
                          Miller Spot Welder
