Cutting straight with Portaband saw
  • Cutting straight with Portaband saw
    Ive got a Milwaukee Portaband saw (thanks for the advice). When cutting anything with depth, square tube for instance, I have trouble keeping the cut on the line on both sides of the tube. Ill start out fine but one side will wander off before Im done. Im sure it would work fine if I had the stand but right now Ive been working off the bed of the pickup.
    Am I watching the wrong side of the tube while cutting? Its very difficult to see the mark on the anvil side of the cut.
    Who do you call when the lawmakers ignore the law?
    Miller AC/DC Thunderbolt 225
    Miller 180 w/Autoset
    Old cutting torch on LPG
    Put the backstop at one corner, (90°) of the square tube, look right down on top the next, (upper) 90 and aim for the 3rd 90. That way you can watch two straight lines at the same time as the blade cuts.
    Caution!
      In case I didn’t make myself to clear, like so!
      Caution!
        portasaw
        Greetings Jesus-nice illustration1 Where do you live?
        Jim
        PHX gringo
          Originally posted by azmac54 View Post
          Where do you live?
          Last driveway on the left, on Seco Street.
          Caution!
            Rose Bowl
            Sounds like Pasadena, Ca
            Dave
            "Bonne journe'e mes amis"
              At the risk of sounding like a smart..., five hundred more cuts and this will be easy......
              Griff
                Dave my balloon is popped! Here I was thinking you are a smart guy, come to find out you’re not the sharpest tool in the shed!
                What part of Sonora don’t you get?
                Caution!
                  Drawing-
                  Sonora Iron I do like your drawing! I think in a past life you might have been a drafter!
                  Kevin
                  Lincoln ranger 305g x2
                  Ln25
                  Miller spectrum 625
                  Miller 30a spoolgun
                  Wc115a
                  Lincoln 210mp
                  F550 imt service truck
                    Oh you should see me with a piece of soapstone and a large concrete floor!
                    Or a puff can and a stucco wall!
                    Caution!
                      Griff, Im trying to avoid the 499 bad cuts. I know if I had a bigger shop with a floor mounted saw it wouldnt be a problem. Ive always had trouble with things like this. Hack saws, sawzalls, circular saws, chain saws, etc. All in all Im REALLY glad I bought this saw.
                        I like that idea! Mike
                          funny!!!!!!!!
                          I'm not late...
                          I'm just on Hawaiian Time
                            I understand! Actually, I had the same problem. Getting started straight is important.
                            Griff
                              I had a lot of trouble making a straight cut with a Porta Band. I've found that if I can get the piece to be cut clamped close to level in the vise, then sight down the back of the blade and lean the saw until I cannot see either side of the blade (only the back edge), then center that blade edge on my mark, I can get a relatively straight cut. The remaining inaccuracy is justification for all those grinders I have laying around....
                              Larry
                              "I feel for the man who can only spell a word one way"......Mark Twain
                              Lincoln AC225-S (OLD/Copper Wound)
                              Lincoln Weldpac 100
                              Miller Matic 180 (auto set)
                              Miller Spool gun 100
                              Miller Spectrum 375 Extreme
                              Victor Super Range II
