Figured I'd post up a message about this new equipment and see what all everyone thinks about it.
Most of what I'm about to ask is probly directed more to Miller reps or service/engineering folks than to the other members, but all comments, opinions, suggestions are certainly welcome!!
http://www.millerwelds.com/products/...ermatic_reach/
I noticed this new feeder on the website recently and thought it sounds interesting. I have a 350P and a Python torch, as well as the QGun. I thought maybe I could leave a roll of aluminum wire in the 350P with the Python hooked up and a roll of steel wire in the Reach feeder with the QGun on it and it would be more convenient in the shop than changing torches and wire.
I notice that the Reach connects to the 350P via the 10-pin torch connector. The Python also connects to the 10 pin torch connector. Is that going to be a problem if I want to have both of them connected at the same time? Does the Reach come with a Y-cable so both units can be connected to the 10-pin at the same time? How would the 350P know which one is being used if they're both connected to the same outlet at once? I know I can connect them alternately when needed, but it would be nice to just have them both connected all the time.
The info says it works with the gun-on-demand and synergic pulse features of the 350P. I don't know if that's only with the QGun connected to the 350P, or if it applies to the Python as well. Do the run-in speed and gas timer features work with the Reach?
Also, I notice the Reach uses an additional, seperate power wire connection back to the 350P that no remote feeder, spool gun or push-pull gun I have uses. Why does the Reach need this seperate connection?
The 10-pin outlet provides 24vdc+ and ground circuits that work fine for powering the spool gun and push pull gun motors. My Suitcase 8RC gets 24vac from the 14-pin connector on my XMT to power it's motor without this extra wire either. What is the wire for?
Is the Reach available with a meter showing the wire speed, since it has the wire speed control on the feeder? I don't see a meter option listed. Are they going to make an optional meter kit available for it?
When using the Reach with the 350P in pulse mode, I it would be nice to have the wire feed speed meter right on the feeder. In pulse mode, the wire speed adjustment is also the heat and is the primary adjustment in pulse, since the pulse is synergic. It would be nice to know, by number, what wire speed is being set, without having to see the front of the 350P while adjusting the wire speed, if the feeder is being used on the other side of the shop.
The final question I have is not really about the Reach feeder, but about the Millermatics. Instead of making the special Reach feeder for use with the Millermatics, why not provide a 14-pin 24vac connector circuit on the higher end Millermatics (350/350P, 252) instead?
With the 14-pin connector, any Suitcase RC or XR Control or 2- 6- or 7-series benchtop feeder could be used with the Millermatic as the power supply. The S74-MPa feeder could be used with the 350P with it's synergic pulse feature too. This seems much more versatile than the special Reach feeder, since the feeder can do double duty with other machines in the shop, or field with the Suitcase RC's.
