Arc Gouging V.S. Oxy ACtylene
  • Arc Gouging V.S. Oxy ACtylene
    I have a heat exchanger to cut up for scrap 60' long 8' dia 1" thick which would be most effective?
    I’d go with O/A, but rent a large liquid oxygen bottle.
    Caution!
      I too 2nd the o/a torch. Where did you find that monster??? ...Bob
        Yep, your not going to be able to successfully use a gouger on it, OxyAcet is the only way, other than using a large plasma cutter.
          A friend of mine has to haul it out of a refinery and wants it cut up into moveable pieces. I was just looking for the easiest way appreciate the info.
            Air carbon arc is going to be much slower and messier than O/A (although it is pretty fun ).
            60a plasma would sever it, 80A would be better. Without that option, I'd use the torch too.
            Syncrowave 250DX
            Invison 354MP
            XR Control and 30A
            Airco MED20 feeder
            Thermal Dynamics Cutmaster 81
            Smith O/A rig
              Plasma is definitely an option, but without moving into a 3-phase unit wouldn’t duty cycle be an issue with a single phase unit?
              Only duty cycle issue I’ve experienced with O/A is the cramp in my thumb!
              Caution!
                I'm sure you already know that all the tubes will be stainless, right?
                Only the shell will be carbon.
                Atleast I've never worked on one with carbon tubes.
                  If this is from a petrochemical facility, there's a good chance you will be dealing with Monel, Incoloy, or another high performance nickel alloy.
                  If so I think it's a safe bet that you won't get very far with an oxyacetylene torch.
                    May want to look into these!
                    http://www.oxylance.net/site/
                    Caution!
                      Yes, exchangers are not generally mild steel. Haven't seen any large Stainless ones either though. So best to check into it, and rent a 80-100 amp+ plasma cutter.
                        Let us know what it turned out to be and what it took to get the job done.
                          Burn the shell with O/A and if the tubes r not carbon then gauge them with carbon arc
                            I work in a refinery and there are all kinds of combinations of shell/tubes in exchangers depending on what product flows thru them. I have read about 400 tags over the years on them...Bob
                              how much time you got ? gouging is definitely the way to go. unless of course your in a major fire zone where space is an option. o/a is good for the shell. but if you have access to an adequate air compressor, then i'd go with the gouge.
