Bernard Q300 Centerfire...Nice gun!
  • Bernard Q300 Centerfire...Nice gun!
    After seeing some comments here and elsewhere on the Bernard Mig guns, I decided to change out my M-25 gun on my MM251 for a Bernard Q300 Centerfire.
    It arrived today and was easy to install.
    I ran a few beads with .045 wire on some 3/8 inch plate and it is really a nice gun!
    A bit heavier and slightly larger than the M-25, but it has a real quality feel to it.
    It makes the M-25 feel like a cheapy by comparison.............. pg
    Dynasty 200 DX_set up on 3 phase
    Coolmate 3
    MM 251 w/ Spoolmatic 30A
    HTP 625 Micro Cut Plasma Cutter
    Victor O/A Rig
    Bridgeport Mill_3 phase (w/ Acu-Rite 4 axis DRO)
    10 inch South Bend Lathe_3 phase
    Baldor Double Cup Tool Grinder_3 phase
    Baldor 10 inch Buffer
    Rockwell 12 inch Disc Sander
    Cyclone 2ft X 3ft Bead Blast Cabinet
    Quincy 325 2stg- Air Compressor_3 phase
    Graymills Built-in Parts Washer
    Rockwell/Delta Planer, HD Shaper, Uni-Saw etc.
    "q-300"
    You can easily convert your M-25 to accept "Centerfire" consumables as well. If the rotatable neck is hard to turn, you might have to stick it in a vise to loosen a little.
    They are nice guns.
    Congratulations
    Dave
    "Bonne journe'e mes amis"
      They are nice guns.
      Congratulations
      Dave
      Dave,i thing the guy who installs the necks at the factory masters the Vulcan Death Grip,Frank
      Millermatic 252
      Millermatic 180
      Hobart spoolmate 3035
      Digital Elite
        Frank and Dave........
        Ha-Ha! Thanks for the tip Dave.
        I loosened the plastic nut (cover) and the neck seemed to be stuck in place.
        I then clamped it lightly in a vise and was able to rotate the handle. Once I got it to move the first time, I tightened and then loosened the nut and can now easily rotate the neck by hand.
        I guess I can go all the way around with the neck (360°) if I wanted to? Although it will be more like 45° in each direction maximum
        as a practical matter. Thanks again.......... pg
        Coolmate 3
        Victor O/A Rig
          PG,all 3 of my guns were the same.And for real hard to reach spots they also have a small adaptor so you can connect a second neck onto the one you have,Frank
          Millermatic 252
          Millermatic 180
          Digital Elite
            Frank......
            Yep! I really thought my gun was not a rotating model from the feel of it. Had I not been given the tip about using a vise to hold it I would still be out there wrestling with it.
            After it did move however, it seems like it is no longer tight and rotates easily.
            I suppose at the factory they really torque down the nut to seat the fitting and the result is a very stiff piece.
            I sure do like the gun though!...... pg
            Coolmate 3
            Victor O/A Rig
              LOL. Congrats on the new gun! Yep, all 3 of mine were v.irgin tight too. Had to use the vice on all of them. Yes, you can spin it around 360 if you want to. Bernard makes a flexible neck you can put on there too. It will bend up to 90 degrees or go straight out with no bend at all, rotates too. I have one for the Passport and it is a cool thing to use sometimes.
              Millermatic175
              MillermaticPassport/Q300
              HTP MIG200
              PowCon 300SM, MK Cobramatic
              DialarcHF, Radiator-1
              Hypertherm PowerMax 380
              Purox oxy/ace
              Jackson EQC
              -F350 CrewCab 4x4
              -LoadNGo utility bed
              -Bobcat 250NT
              -PassportPlus/Q300
              -XMT304/Optima/Spoolmatic15A
              -Suitcase8RC/Q400
              -Suitcase12RC/Q300
              -Smith oxy/propane
              -Jackson EQC
                Thanks DR.
                I will check out that flexible neck. That seems like it would be an advantage to have one.
                I can also see where I am going to like turning the neck left 45° to weld up in corners with the Q300.
                You were one of the guys whose comments drove me to get the Q gun. Thank you...... pg
                Coolmate 3
                Victor O/A Rig
                  LOL. I knew you'd like that Bernard.
                  The only bad thing about the flexy neck is it's a bit pricey.
                  Millermatic175
                  HTP MIG200
                  Purox oxy/ace
                  Jackson EQC
                  -F350 CrewCab 4x4
                  -Bobcat 250NT
                  -PassportPlus/Q300
                  -Suitcase8RC/Q400
                  -Suitcase12RC/Q300
                  -Smith oxy/propane
                  -Jackson EQC
                    Sob
                    I sure am glad I read this thread. I tried loosening and rotating mine the other day. After a while I thought maybe I got screwed. I got the nut loose with a pipe wrench but couldn't rotate the neck by hand, I'll put it in the vise tomarrow.
                    Hey, what about these jumper liners? The original gun itself doesn't have one. Or does it? I guess when the old liner goes bad you cut out the correct length and add in the jumper liner.
                    '08 F-350
                    Vantage 400
                    SA-250
                    SA-200
                    Invertec V350Pro
                    Invertec V205T-AC/DC
                    Miller 12VS suitcase
                    Miller spectrum 2050
                    Pipe beveler's
                    Track torch
                      Yeah they just come with one continuous liner when new. I've never used the jump liners but I think next time I'll try it instead of buying a new liner.
                      Millermatic175
                      HTP MIG200
                      Purox oxy/ace
                      Jackson EQC
                      -F350 CrewCab 4x4
                      -Bobcat 250NT
                      -PassportPlus/Q300
                      -Suitcase8RC/Q400
                      -Suitcase12RC/Q300
                      -Smith oxy/propane
                      -Jackson EQC
                        What does the jumper liner do and how does it work. I ask because I might be getting a bernard gun for my passport plus next week for my birthday
                        Hobart Mega Arc 5040DD (with built in air compressor)
                        MM Passport Plus with Q-gun
                        O/A
                        sold MM 251
                        There are only 2 tools needed in a tool box. 1) Duct tape to fix any thing that moves that isn't supposed to. 2) WD40 to fix anything that doesn't move but should.
                          With a new gun it will have a one pc. liner in it,the liners wear in the neck where the radius is so when that area gets worn just cut the old liner off and install the jump liner it's only about 12" long .i have 5-6 of the 300
                          2 ea Miller Big 40 Cat cc cv Deluxe
                          1ea Miller 400P cc cv Deluxe
                          Miller Big Blue 300 Pro cc cv
                          XMT 304 cc cv
                          Miller 350P-XR-A Aluma Pro
                          Miller 30A
                          1ea X-Treme 12vs
                          2ea Miller 12Rc
                          Miller 24 A
                          Miller 330 a/bp tig
                          Dynasty 200 DX coolmate 3
                          Millermatic 180
                          Millermatic 180 auto set
                          Lincoln Invertec 350 Pro
                          Lincoln Idelarc SP 250
                          2ea Lincoln LN-25 wire feeders
                          2ea Powermax 1000
                          1ea Bortech 300z Borewelder
                            how do you know when its time to change the liner
                              "Time For Change"
                              When it's worn out
