Originally posted by Don52
View Post
Help with TIG welding
I had something quite similar happen last week and again today. Seems to be in the steel as everything before the porosity laden spot welded fine and after it welded fine. Just had 2 spots in the sheet I guess where it had been contaminated at the mill. I don't know the origin of the steel as we bought it off a third party. I was also working with an aluminum extrusion (which came from an extruding mill in New Jersey (I should have stuck to the extrusions made in Jackson Ohio))over the weekend and lo and behold what did I find in it? A steel sheet metal screw. I guess quality is out the window nowdays!!!
So maybe it's nothing you've done wrong but just a bad spot in the material. The shop next door just rejected an entire load of sheet steel today because of laminations.Blondie (Owner C & S Automotive)
Miller 340A/BP
Victor O/A torches
Lincoln SP125
Too many other tools to list
03 Ram 1500
78 GS1000
82 GL1100 Interstate
When tigging steel it can be overheated easily causing porosity, I notice it on the thin gage pipes I make. Adding filler will fix the problem temporarily, but if overheated again it will do the same thing again.
I believe you were using a gas lens, keep the tungsten sharp, a touch of flat on the end, a contaminated tungsten will make the problem worse as will contaminated argon.
I have tigged stainless for years and the mild steel is tougher getting used to.
A foot or finger control is a great help, takes a bit of practice to get the hang of it.
Purging the tube would be good too, lack of it really shows up on thin gage materials.
I am using about 10 cfh argon .040 tungsten, 5/16" cup on the work I am doing. I wouldnt go too high on the gas flow as it can cause turbulence.
Maybe some of this will help you, I am kind of new to the steel tigging as well.mike sr
Originally posted by aspeyrer View PostI am having trouble welding some DOM A 513 tubing with my Miller Maxstar 150 STL model. the tubing is 1 1/4" OD by .095 wall, Notched at a 45 degree angle. The only area of the tubing that gives me trouble is the back side of the 45 angle, as soon as i start to drop in filler, the filler starts to bubble, if i add more filler, the weld looks okay for a second, then bubbles again, the weld there looks like a glob of swiss cheese. Thanks Alan
P.S. check out my website aesracingllc.com
JimDynasty 300DX
MM350P
Hobart Handler 120
Smith LW7, MW1, AW1
Smith AR/He Mixer
popspipes, I think i will try to weld the entire piece of tubing, except the back side of the 45 degree angle. I will weld the backside of the 45 degree angle after the tubing has cooled, like maybe the next day after, and see if it makes a difference
clean and brush the area helps too, once its overheated addding filler will correct it, but dont overheat it again or the problem will reoccur.
I have found that the more quickly you do the weld the better it is for the steel as far as the gassing goes.
Different alloys of steel react differently too I have found.
You will get it, steel just takes some getting used to.mike sr
Originally posted by tigguy View PostNo contaminants on the inside of the pipe? Shipping oil, grease? Cleaned all of the mill scale off, inside too?
Anybody check out my website: aesracingllc.com
Yeah, i know, shameless plug for me
