Hello to all.
Today I tried my first ever stainless steel welds with the Millermatic Passport.
Wire used was 0,030" 308 LSI and shielding gas was 98% Argon/ 2% CO2. Layed a few beads on some scrap 304 tubing, 0,10" thick I have. I followed the chart settings for tri-mix and set the machine in stainless mode DCEP.
To my surprise I had a lot of spatter. I have no option on using tri-mix because it is not available here.
Checking the Miller resources I see that for short circuit it is recomended tri-mix or 75% Argon/ 25% CO2 and 98% Argon/ 2% CO2 for spray transfer only.
I have the posibility to return the 98/2 bottle of gas, and get a 75/25 one.
What do you think? Will I be able to get better results with 75/25 in stainless steel than I did?
I have had great results with steel wire and CO2 only, so I suspect this spatter I am getting with SS may be due to unsuitable gas blend for the task.
Your input will be greatly appreciated. Thanks!
Regards:
Jerónimo.
Regards:
Jerónimo.
