Been looking into it my self so fare it looks to be the cheaper rout for set up about 400.00 cheaper or so.But am not looking to do any cutting with it only brazing and heating.People Ive talked to say if you learn to set it up just right it cuts real good.
propane cutting torch
You can not weld with anything but acetylene
All other fuel gases can only be used for cutting, heating and bending, soldering and some brazing. You can not weld with a filler rod added to puddling metal and get a proper welded joint.
Makes no Difference what it says on the box or companies web site. They make use of terms very loosely,they will tell you something completely different if you pin then down.
glen, If your not on the edge, your wasting space
Originally posted by PTsideshow View PostYou can not weld with anything but acetylene
Millermatic140; Spectrum625; Bobcat250; Lincoln AC225; Bosch grinder
Originally posted by SGS Welding View PostHydrogen is for aluminum.
http://www.youtube.com/watch?v=DpQOfOlA17Y
http://www.youtube.com/watch?v=9-fvmAg8L_gLast edited by CarbedNotch; 09-13-2009, 08:29 PM.Millermatic140; Spectrum625; Bobcat250; Lincoln AC225; Bosch grinder
The reason acetylene is used as the fuel for welding steel is due to the fact that the other fuels result in high concentrations of hydrogen in the flame, which get into the weld.
For steel, hydrogen = bad. Propane will weld steel if you have the right tip, but the weld will be complete garbage due to hydrogen embrittlement and cracking.
As far as cutting with propane...
I have used propane for years and it has saved me huge amounts of money over time. Propane heats just as fast as acetylene (if you have the proper size tip) and the quality of the cut is identical. After all, the stream of oxygen is what does the cutting. The gas only preheats the metal to bring it up to a reactive temperature. And as far as the temperature of the flame, 5100F vs 5700F, that's almost completely irrelevant for two reasons. First, that's way past the melting range of steel. Second, propane makes more energy per unit volume than acetylene. For a practical example of what it means for one medium to have a higher energy density at a slightly lower temperature, try the following:
Put your hand in a 250 degree oven and feel the hot air. Now put your hand in a stream of 220 degree live steam and feel the difference. The steam is colder than the oven, right? But it has a higher energy density (like propane flame) and that's why it burns you instantly.
That said, why isn't propane more popular?
The problem is that:
1-Some people try to use propane with an acetylene cutting tip. It will hardly cut sheet metal and they tell everyone and their brother how bad propane cuts.
2-Some people actually have a propane tip, but they don't adjust the flame right. As strange it would seem, it adjusts differently than acetylene.
3-Some people try to cut with the preheat flame impinging the inner cone on the the steel (like you would with an acetylene flame), with terrible results. You must heat your cut with the very outer tip of the flame cones.
4-Some people expect a propane tip of similar diameter to do the work of a similarly sized acetylene tip. Propane tips run larger.
I use propane and love it. One great advantage is being able to run any tank full bore without worrying about it exploding.
