Dynasty 200 is a beautiful welder .... when it's working
    I hear you on the cost thing Lewis . It's an expensive addition if you really don't have a need for it very often ( like me ) .
    Miller MM252 with Bernard Q300
    Hypertherm PM30
      I'm kind of cheap at times but usually crack and buy stuff after I have stewed on it a while - maybe it's an age thing - haha.
      Just heard from the service guy - looks like he's going to be ordering up a high frequency board for the welder - I asked him if it would be a few weeks and he said it could be done as early as Friday ! Apparently the boards are overnighted out most of the time.
        Well , let's just hope that this will be the last of your troubles with this machine . Holy crow .
        Hypertherm PM30
          I'd be interested to know the final cost, seeing as how I have a Dynasty 200 DX...
          "If you build it, they will come!"
            Marcel -
            My unit is under warranty but I'll ask the service guy what the cost would have been and let you know.
            • #21
              Aerometalworker, what is a "burn-in table"?
              Aside from operating all of my electronic devices at frequent intervals (a chore; we have an inordinant number of electronic devices of all kinds), what else can we do to prolong their reliable operation?
              I would imagine humidity is a factor(?). A lot of generator-welders spend their lives out in the weather, atop a service truck. Some are used daily, some are used only occasionally. Presumably these machines are to some degree designed to tolerate this environment, but are there protective spray-coatings that would reduce corrosion of exposed wire strands, for example?
              • #22
                Just picked up the machine from the shop. With the long weekend the delay was a bit more than usual. Seems the HF board was gone - Miller flew another one to the shop and now it's working fine again.
                I asked the fellow what something like this would cost if the machine was out of warranty and he said he did not ask but suspected it would be in the 100s.
                Now then, back to the coupons and practicing !
                • #23
                  Hey LC i'm glad you got the little fellow fixed and back up and running.
                  2 ea Miller Big 40 Cat cc cv Deluxe
                  1ea Miller 400P cc cv Deluxe
                  Miller Big Blue 300 Pro cc cv
                  XMT 304 cc cv
                  Miller 350P-XR-A Aluma Pro
                  Miller 30A
                  1ea X-Treme 12vs
                  2ea Miller 12Rc
                  Miller 24 A
                  Miller 330 a/bp tig
                  Dynasty 200 DX coolmate 3
                  Millermatic 180
                  Millermatic 180 auto set
                  Lincoln Invertec 350 Pro
                  Lincoln Idelarc SP 250
                  2ea Lincoln LN-25 wire feeders
                  2ea Powermax 1000
                  1ea Bortech 300z Borewelder
                  • #24
                    Good to hear your back in business Lewis!! I am just turning 50 hours on mine, that hour and arc counter are nice.......
                    I just got in a new order of pipes so I will add about 10 to 12 more hours to that and use another 250 cu ft of argon..
                    So far mine has been good other than the help 1 code once in a great while.
                    mike sr
                    • #25
                      Originally posted by Aerometalworker View Post
                      Ha Ha , no im not union......thankfully. But it seems the company is making a final gesture and allowing another vote due to the gross failure on the union leaderships part to conduct an educated vote on their own.
                      There was a story on the radio about the Stillwater Ok. plant adding jobs when the Wi plant closes. 2 or 3 days later the story changed to jobs moving to Wi since the Labor dispute was resolved.
                      Dennis
                      Thermal Arc 185-TSW
                      Millermatic Challenger 172
                      VictorO/A
                      Atlas Craftsman 12 by 24 Lathe
                      Esab PCM-875
                      Wholesale Tool Mill-Drill
                      • #26
                        Lewis,
                        If you decide to go with a fingertip remote, I'd recommend you also look at the CK brand. They have a N/S switch that requires considerably less movement than the Miller N/S switches.
                        They also have a rotary control, which I haven't used, but that seems to also require a good deal of movement.
                        Also, the CK remote is a little less coin than the Miller. Works great on the Dynasty.
                        PS. Just do a google search for CK Torches. They have a good site that shows the remote very well.
                        Syncrowave 250 DX Tigrunner
                        Miller MM 251 w/Q300 & 30A SG
                        Hobart HH187
                        Dialarc 250 AC/DC
                        Hypertherm PM 600 & 1250
                        Wilton 7"x12" bandsaw
                        More grinders than hands
                        • #27
                          Originally posted by SundownIII View Post
                          Lewis,
                          I'll make a note of that. Thanks for the tip !
                          Cheers,
                          Lewis
                          • #28
                            Don't forget you can use a momentary contact control and use the 2T and the 4T settings to adjust amperage. (Ramp up and Down). I'm not sure but I suspect the spot weld mode would be arc on for the adjusted time only and not be able to ramp up or down.
                            Dennis
                            Thermal Arc 185-TSW
                            VictorO/A
                            Esab PCM-875
                            • #29
                              Hope you got your help 1 fixed. Usually just by resetting the power, it should go away. You should send the machine for repair if the help 1 is repeatable consecutively.
                              • #30
                                Hi -
                                Yep, it seems to be fixed this time. The service shop ended up replacing the HF board the last time I had the machine into them, and I have not had a help-1 error since before that. Perhaps they were related.
                                Cheers,
                                Lewis
