Can someone tell me about the plate certification test that would be all position with a backing plate? I have taken this test years ago and I'm wondering if I supply the welding rod and what specific rods will be used. I imagine 6010 or 6011 and 7018 to fill and finish, my past tests were administered by the company Q.C.. This test I go to the tech college and the company I work for pays the bill. 350.00
welding certification
If it's a plate test with a backing bar, it will be 7018 all the way out. If it were an open root test, then it would be 6010 and 7018. The test administrator usually provides the test plates, backing bars and electrodes.Millermatic350P/Python, MillermaticReach/Q300
Millermatic175
MillermaticPassport/Q300
HTP MIG200
PowCon 300SM, MK Cobramatic
DialarcHF, Radiator-1
Hypertherm PowerMax 380
Purox oxy/ace
Jackson EQC
-F350 CrewCab 4x4
-LoadNGo utility bed
-Bobcat 250NT
-PassportPlus/Q300
-XMT304/Optima/Spoolmatic15A
-Suitcase8RC/Q400
-Suitcase12RC/Q300
-Smith oxy/propane
-Jackson EQC
Thanks desert rider, just one more thing, the size of the two coupons are they 6"x8"x3/4" 45 degree bevel. Thanks for the info I just want everything correct for my practice welding.Big Blue 300
Miller 175
Cutmaster 75
Dewalt chopsaw
Makita chopsaw
'89 Dodge W/ custom flatbed
Grinders
Wildcat 7"
Makita 5"
Milwaukee 4 1/2"
Dewalt 4 1/2"
if you take the test on 3/8 plate you'll be good up to 3/4, take the test on 1" you be good for unlimited, I took the 1" 7018 3g, like always clean chip take your time good luckTrailblazer 302G
MM 210 with spool gun
Thermal Arc Heffty2 CC/CV suitcase
Smith torches
Porter Cable 14" carbide chop saw
griders and hand tools coming out the WAZOO
I owe! I owe! so off to work I go!
Yeah 3/4" is kinda odd plate thickness for a cert test. May as well do another 1/4" more and be unlimited qualified. Maybe this test is for a specific purpose and not a general D1.1 test?Millermatic350P/Python, MillermaticReach/Q300
Millermatic175
HTP MIG200
Purox oxy/ace
Jackson EQC
-F350 CrewCab 4x4
-Bobcat 250NT
-PassportPlus/Q300
-Suitcase8RC/Q400
-Suitcase12RC/Q300
-Smith oxy/propane
-Jackson EQC
For ASME, 1/2" test thickness is unlimited weld (max the procedure allows)
For ABS and Coast Guard, 3/4" is unlimited thickness (mas the procedure allows)
Depends on the code.
Some requirements on jobs/specialty codes require qualification on actual thickness (no allowance for 2t or unlimited). I have a HSLA procedure that is spec'd this way, as heat input is critical to the application.
Thanks for the info. It sounds like I need to talk to the CWI administering the test to get the details I need. This forum is so awesome.Big Blue 300
Miller 175
Cutmaster 75
Dewalt chopsaw
Makita chopsaw
Grinders
Wildcat 7"
Makita 5"
Milwaukee 4 1/2"
Dewalt 4 1/2"
