Millermatic 200 on aluminum tips please.
  • Millermatic 200 on aluminum tips please.
    Hi everyone. I've done quite a bit of tig welding on aluminum and more than my fair share of mig on steel. What I haven't done much of is migging aluminum. The boss tells me that the old spool gun on the Millermatic 200 is probably shot and he wants to buy a new one. So my FIRST question is: Which spool gun should we buy if , indeed, it IS shot? Secondly, any tips on settings would be grand. I used to use a Miller 250P on aluminum and it was great. Of course, we used 100% Argon for the shielding gas. Also, we are welding 6061 and mating 3/8" to 1/2" material. The 3/8" is a stair tread and is milled so there are 3 tabs on each end of the tread. These tabs fit into holes drilled into 1/2" x 8" 6061 "U" channel. I assume that we will need to pre-heat, yes? Also, what kind of quality should I expect from this machine mated with a new spoolgun? Thanks in advance for even a PARTIAL reply to my diatribe Thanks so much!
    Miller 350P XR push/pull
    Miller 250 DX
    Spectrum 2050 Plasma
    Well I'd just fix the gun if indeed it is shot, probably a spoolmatic 1. Problem with these is generally in the control cable.
      Wow, that's some thick aluminum. I think you're going to be under powered with only a 200 amp mig and 3/8 to 1/2 inch plate t-joints.
      Millermatic175
      MillermaticPassport/Q300
      HTP MIG200
      PowCon 300SM, MK Cobramatic
      DialarcHF, Radiator-1
      Hypertherm PowerMax 380
      Purox oxy/ace
      Jackson EQC
      -F350 CrewCab 4x4
      -LoadNGo utility bed
      -Bobcat 250NT
      -PassportPlus/Q300
      -XMT304/Optima/Spoolmatic15A
      -Suitcase8RC/Q400
      -Suitcase12RC/Q300
      -Smith oxy/propane
      -Jackson EQC
        MM200 is conservatively a 275amp machine @ approx 35% duty cycle..
        it is severely underrated... specs nearly identical to the MM252...
        hope this helps
        Heiti
          revlimit,
          I guess I don't understand.
          In your signature you show a MM350P with push/pull.
          Have you never used that machine for mig welding aluminum?
          Is this a personal machine and you don't want to use it on the jobsite?
          Have you even had the spoolgun for the MM200 checked out by a competent repair facility (before declaring it shot)? If your boss is sure he wants to buy a replacement spoolgun, it's my understanding (Cruizer would be better informed than I am) that the 30A will work on the MM200, but will require an additional controller.
          More questions than answers in this post.
          Syncrowave 250 DX Tigrunner
          Miller MM 251 w/Q300 & 30A SG
          Hobart HH187
          Dialarc 250 AC/DC
          Hypertherm PM 600 & 1250
          Wilton 7"x12" bandsaw
          More grinders than hands
            hope this helps
            Heiti
            MM200 is rated the same as the MM252. 60% duty cycle at 200 amps.
            Millermatic Passport Plus
            Millermatic 350P with Python
            XMT 304 /w S-64 feeder and 12VS
            Dynasty 300 DX
            Thermal Arc 400 MST
            Premier Power Welder for my trail junk.
              Crawler
              Miller used to really underate their machines... [email protected]% is right for both machines... as is much higher at shorter duty cycles.... and from my experience with the antique MM200 that I have... their published specs were very very conservative... they are a very stout machine..
              Heiti
                Let's get the facts straight regarding the MM200 and the MM251.
                Both machines are rated at 200A output at 60% duty cycle.
                The MM200 has a max output of right at 260A.
                The MM251 has a max output of just over 300A.
                The are NOT the same output machines.
                The MM200 was/is a great mig welder which set the standards for the all in one mig welder.
                The MM251/MM252 has features not available on the MM200 to include being spoolgun ready, and gun on demand.
                As has been mentioned, the MM200 was conservatively rated. By the same token, so is the MM251/252.
                Hobart HH187
                Dialarc 250 AC/DC
                  Sundown
                  we are in basic agreement.....
                  tnx
                  Heiti
