12 RC Digital Readout Issues....195 194 Install Questions
  • 12 RC Digital Readout Issues....195 194 Install Questions
    I have a 12 RC at both work and at home. I sourced two 195 194 Remote Voltage/Current Setting kits from Miller.
    Problem is the instructions only cover serial numbers through LF.
    Serial number at work is LJ, mine at home is LK.
    How do I install these kits? Do I even need them? I thought I did.....I want the meters to read volts and amps.
    Big 40 Deluxe CC/CV at work with the Cat diesel (2007).....TB 302 at home I bought November '08.
    Thanks,
    Allen
    Big 40 Deluxe
    12RC
    WC-24
    30A
    Dynasty 700
    XMT 456
    Custom Cart w/the following:
    S-74DX
    Optima Pulser
    Coolmate 3
    XR Control Box
    XR Alumna Pro Python W/C
    CP 302 w/22A
    MM210
    Synchrowave 180 SD
    Spectrum 2050
    TB 302
    12RC
    WC-24
    30A
    HF 251 D1
    Dynasty 200 Coming Soon
    Have you tried calling Miller wire feed service?
    They would be better at handling this type of question since it's about a specific product ser# timetable.
    920-735-4505
    Good luck
    Andy
      Did your 12RC's come with meters installed in them from the factory? My 8RC with factory meters reads volts, amps and wire feed speed as-set-up from the factory, no additional kit needed.
      Millermatic175
      MillermaticPassport/Q300
      HTP MIG200
      PowCon 300SM, MK Cobramatic
      DialarcHF, Radiator-1
      Hypertherm PowerMax 380
      Purox oxy/ace
      Jackson EQC
      -F350 CrewCab 4x4
      -LoadNGo utility bed
      -Bobcat 250NT
      -PassportPlus/Q300
      -XMT304/Optima/Spoolmatic15A
      -Suitcase8RC/Q400
      -Suitcase12RC/Q300
      -Smith oxy/propane
      -Jackson EQC
        You need meter kit #300178 covers the 12RC AFTER LF232631.
        I can download the manual to you if you wish..
          No.
          I don't need the meter kit.
          They were factory installed.
          The 195 194 Volt/Current sensor kit allows the meters on the the suitcase feeder to display voltage/amps or IPM in power sources not having pins F and H in the 14 pin connector.
          According to Miller's literature, the only power source having those pins is the PipePro 304.
          My meters read gibberish on the Big 40. Never tried it on the TB 302 but I expect the same.
          Big 40 Deluxe
          12RC
          WC-24
          30A
          Dynasty 700
          XMT 456
          S-74DX
          Optima Pulser
          Coolmate 3
          XR Control Box
          CP 302 w/22A
          MM210
          Synchrowave 180 SD
          Spectrum 2050
          TB 302
          12RC
          WC-24
          30A
          HF 251 D1
            I use my 8RC with my XMT304 CC/CV and ALL the info is displayed just fine....
            Millermatic175
            HTP MIG200
            Purox oxy/ace
            Jackson EQC
            -F350 CrewCab 4x4
            -Bobcat 250NT
            -PassportPlus/Q300
            -Suitcase8RC/Q400
            -Suitcase12RC/Q300
            -Smith oxy/propane
            -Jackson EQC
              Great!
              When I use the 12 RC with my XMT 465 it displays ALL the info just fine as well.....because my guess is the 304 and 456 use pins F and H.
              Go plug your 8RC into any engine drive other than the PipePro 304 and see what happens.
              You'll be buying the same kit I just bought.....
              Big 40 Deluxe
              12RC
              WC-24
              30A
              Dynasty 700
              XMT 456
              S-74DX
              Optima Pulser
              Coolmate 3
              XR Control Box
              CP 302 w/22A
              MM210
              Synchrowave 180 SD
              Spectrum 2050
              TB 302
              12RC
              WC-24
              30A
              HF 251 D1
                Sounds like you already knew the answer to your own question. So, buy the kits and put them in!
                Millermatic175
                HTP MIG200
                Purox oxy/ace
                Jackson EQC
                -F350 CrewCab 4x4
                -Bobcat 250NT
                -PassportPlus/Q300
                -Suitcase8RC/Q400
                -Suitcase12RC/Q300
                -Smith oxy/propane
                -Jackson EQC
                  "J" and "K" come AFTER "F".
                  You've been oh so helpful. Thanks.
                  Big 40 Deluxe
                  12RC
                  WC-24
                  30A
                  Dynasty 700
                  XMT 456
                  S-74DX
                  Optima Pulser
                  Coolmate 3
                  XR Control Box
                  CP 302 w/22A
                  MM210
                  Synchrowave 180 SD
                  Spectrum 2050
                  TB 302
                  12RC
                  WC-24
                  30A
                  HF 251 D1
