AC TIG: balance control vs. differential current adjustment
  • AC TIG: balance control vs. differential current adjustment
    I started a new job back in February, and I use a Dynasty 350. I weld mosty stainless, but I get quite a bit of aluminum as well, and I have been having trouble getting heavier aluminum to weld decently. (I weld alot of 1/2" aluminum, and some thicker.) I have been experimenting with settings quite a bit, but I would really appreciate some knowledgeable guidance.
    I have a question about AC current settings for TIG welding aluminum when using an advanced power source like the Dynasty 350. I am not quite sure how to word this, but what is the difference between increasing the balance control (for more penetration and less cleaning) and changing the ratio of EP and EN current (increasing the EN and decreasing the EP, for more penetration and less cleaning)? I undertand that the differential current control affects the actual amperage each of "side" of the AC wave, and that the balance controls the proportion of time that the arc spends on each side regardless of current the current setting. But do these two approaches simply achieve the same thing in different ways, or is there a difference in the arc? I hope that question makes sense.
    It seems to me that achieving the more penetration/less cleaning condition by turning up the EN and/or dropping the EP gives more of a sharp, biting, and harsh arc, while leaving the EP a little higher and turning the balance up gives a focused but smoother arc with a more fluid puddle, maybe? Has anyone else made observations like this? (My observations may not be very accurate because I have the bad habit of trying to make too many adjustments at once.)
    I have been trying to get the most heat I can out of the machine for welding thick aluminum, and I tend to dislike the arc characteristics I get when I have the settings really cranked up. (I am sure there are some technique issues involved as well.)
    I would appreciate any info, observations, or advice anyone might have on this. Thanks much!
    -mjc
    mjc,
    You are correct in saying they do somewhat have the same effect. By lowering the EP, the cleaning zone does decrease and so does the average amperage. while changing balance, the cleaning changes but the average amps do not.
    When running less EP, the amp swing from EP to EN is less severe and is less destructive on tungsten. If you are looking for increased power at the weld, you can turn the EP down, EN up and increase the main amperage to suit your material thickness. Try a 2/3 EP ratio at first and go as high as 1/2 if less cleaning can be used. Example: 2/3 ratio would be 200 Amp EP, 300 Amp EN, and a 1/2 ratio would be 150 A EP and 300 A EN. If you get too low on your EP you will not get enough cleaning and your welds will grey up and look bad especially at the toes.
    The frequency focuses the arc. Higher the number, tighter the arc will be. The freq setting will be determined by joint design. If you have an outside corner joint, the freq should be less to tie in the toe edges. If the joint is an included angle where you have to weld in a tight spot, turn the freq much higher to get in the tighter, deeper joint.
    Turning the freq up will also put more heat in a tighter area which will also give deeper penetration.
    Hope this helps.
    A-
      Ed Conley
      MM252
      MM211
      Passport Plus w/Spool Gun
      TA185
      Miller 125c Plasma 120v
      O/A set
      SO 2020 Bender
      You can call me Bacchus
        mjc79,
        Can't make things any clearer than Andy has already done.
        I would make one additional suggestion on something to try. If you're using the advanced squarewave (AC Waveform) try shifting to the "soft squarewave". That may take some of the harshness you're experiencing out.
        You didn't define "thicker aluminum" in your comments, but assuming you're pushing the machine limits, you may wish to try adding a little (10-25% helium) to your gas mix. Will result in a much hotter arc.
        Syncrowave 250 DX Tigrunner
        Miller MM 251 w/Q300 & 30A SG
        Hobart HH187
        Dialarc 250 AC/DC
        Hypertherm PM 600 & 1250
        Wilton 7"x12" bandsaw
        More grinders than hands
          Good point on the Helium.
          A-
            Guys
            this is just one example of the types of questions that would be addressed by the Dynasty Textbook/Handbook
            tnx
            Heiti
              Dc gtaw
              Have you considered running DC GTAW with UHP+ helium? It is a completely different process and your customer may not accept it. If interested, do a thread search. Penetration results may surprise you. You can use a lower amperage with smaller tungsten and not out the max out your machine. It does take practice. I have several posts regarding this process as do a few others. I know NASA has specs for certain aluminum alloys using this process. Good luck.
                Wes
                Great to see you back!!!!!
                Heiti
                  Hawk,
                  Pangea (works for NASA) and BC on the Hobart board are big fans of DC and "lab grade" helium for heavy aluminum weldments.
                  I've used DC/straight Helium quite extensively in the past, but for many years now, I've found I can get my work done with AC and the addition of about 25% helium.
                  DC welding with Helium definitely has it's place, but when you factor in the cost of the Helium along with the higher flow rates required, your covering gas ends up costing you about 7 times as much as using Argon.
                  Sometimes you just got no other options though.
                  Hobart HH187
                  Dialarc 250 AC/DC
                    Originally posted by ASKANDY View Post
                    mjc,
                    A-
                    I have not experiment much with the setting. Right now 3/4 ratio.
                    Question:
                    As long as I see the cleaning area around the weld bead and no graying (even at the toes) can I assume that I have enough cleaning?
                    Slightly different question:
                    Which is a better indicator of enough cleaning, the color of the bead, or the size of the cleaning zone around the bead?
                    Con Fuse!
                    Miller Dynasty 350
                    Millermatic 350P
                    -Spoolmatic 30A
                    Hypertherm PowerMax 1000G3
                      Fans of DC GTAW on Al
                      sundown.
                      Hawk,
                      Yea. I know what you mean. The process has been used for years in obscure (to the public) circles. I was really thinking about the final weldments/product(s). When you use 60-70CFH of UHP+/labgrade He it costs big time! Maybe it's just me, but I love to feel the filler penetrate like it does running .040 ceriated tungsten at 140 amps on 3/4" Al. Also pushing 300+amps AC is hotter than helle (had to add an e for the forum to allow it) to me.
                      I am nearly 50 and can't count the bottles of high dollar He, tungsten, and filler rod I smoked up over the years. The final product and selling price was good. Now days I rarely see over 40 amps on a TIG. All I do is weld critical stuff with no tolerance for error. Good to hear your input though.
                        DC Tig on aluminum
                        Hello Hawk,
                        I do a little tig welding and am fair on alum but I do not consider myself an aluminum welder.
                        My buddies call me the "Clouseau" of tigging.
                        But this thread has me intrigued as I thought DC tigging aluminum was a no-no.
                        I do not have access (too cheap!) to helium so I am stuck with argon.
                        I would love to try tigging alum on DC but am I doomed if I don't have helium or can I try with your suggestions for settings?
                        Here are two 3" cubes I made from 1/8" alum (alloy unknown with 3/32" 4043 wire )
                        If I remember correctly, this was done at 85 amps - 150 hz - 75% balance - advanced squarewave on my Dynasty 350 (pre - blue lightning feature.)
                        thanks,
                          Waste of time...
                          Nice work Closeau!
                          I tigged a 3x3 stainless cube most of the way, filled it with water and welded it shut. It took a couple of trys adjusting the heat. It's full of water and hopefully won't rust. It's kinda like your picture, but SS and solid.
                          Nice work on your welding!
                          Actually it is a waste of time without helium. I have never had any luck with plain jane helium. Argon will not work with this procedure. It has to be an Ultra High Purity grade gas which costs too much to play (unless you got it like that). I used to run DC GTAW a lot on 1/2 and thicker -TX alloy because it maxed out my 300DX to run AC and it was too many passes. I like to get it done and move on to something else.
                          I really have not given specific settings because it is an expensive process to run. I never messed much with it except on a job to job basis. If you are really interested. look up some of my old posts. I think it is all there. If not, let me know and I can send you some specs via PM or I can post to the forum. Let me know.
                            Hawk,
                            LOL,
                            Most of my "heavy aluminum" involves marine engine beds and support brackets.
                            Give me my 304, Optima Pulser, and 30A spoolgun and we're ready to rock and roll on the heavy stuff.
                            I'm "a bit" older than you, but never found high amp tig welding very enjoyable. In fact, I can't imagine tigging with a Dynasty 700 maxed out.
                            Hobart HH187
                            Dialarc 250 AC/DC
                              Too hot
                              SundownIII,
                              High amp GTAW is very uncomfortable. I am one of those guys that keep on pushing the torch until the weld is finished or it gets too hot to run it. I miss my XMT Omptima, and 30A. My ex has or had it all. She was supposed to sell everything along with all my Dynastys, Engine drives, etc and subtract it from what I owe the settlement.
                              Yea man that is the way to do it if you can get away with wire. So much of what I did over the years was 3/4" through 2" -T6 flat bar bends. The runs were short (2"-6") so the DC Tig was almost perfect for the application. I have never struck an arc with the D700. I hope to soon. I think I can find one to demo soon. I cannot afford one for a while-really don't need it now.
                              It is really great to hear from you.
