Dynasty Processes-Set Up
This is a sticky topic.
  • Dynasty Processes-Set Up
    It has been requested by a few people to have a dedicated INVERTER thread and stick it.
    This will be a thread mainly for Dynasty machines with their multi set up features. Diversions, while Inverters, are pretty basic and don't really belong in this group.
    This thread is for specific questions regarding set up, menu features, processes or general experiences that feature the Dynasty type machines.
    There also have been a lot of requests for a Dynasty book. Even though this is a GREAT idea and has been looked at, our resources at this time are too thin to take on this exhausting task. It's not as easy as jotting down notes on how the Dynasty welds. It has to follow a progression of features and benefits along with weld samples and practical applications examples.
    If and when the economy picks back up and we gain some additional weld engineers, an in depth book on Dynasty functions could be possible.
    Until then, this thread should help gather some data to help our advanced inverter users and be a collective area where our weld engineers can browse, time willing, and participate.
    This is NOT an area for service issues. I'd like to keep this welding related.
    Thanks!
    Andy
    A super idea; I for one will be looking forward to seeing it. Many thanks
    Harold
    Harold
    Craftsman Colormatic AC
    Victor Journyman Setup
    Syncrowave 180 SD
    MM210 With Spoolgun
    Dynasty 200 DX
    Spectrum 625 Plasma Cutter
    Miller HD Tape Measure
      I will watch this thread on a regular basis too.
      pg
      Dynasty 200 DX_set up on 3 phase
      Coolmate 3
      MM 251 w/ Spoolmatic 30A
      HTP 625 Micro Cut Plasma Cutter
      Victor O/A Rig
      Bridgeport Mill_3 phase (w/ Acu-Rite 4 axis DRO)
      10 inch South Bend Lathe_3 phase
      Baldor Double Cup Tool Grinder_3 phase
      Baldor 10 inch Buffer
      Rockwell 12 inch Disc Sander
      Cyclone 2ft X 3ft Bead Blast Cabinet
      Quincy 325 2stg- Air Compressor_3 phase
      Graymills Built-in Parts Washer
      Rockwell/Delta Planer, HD Shaper, Uni-Saw etc.
        Thanks for the good anwers! I have been trying the "soft" square wave, and the following settings
        300 amps EN
        150 amps EP
        80% balance
        (the frequency has varied, depending on the joint configuration).
        Oh, by the way, I am mostly welding on 1/2" aluminum. (Sometimes it is as thick as 1" though.)
        These parameters have been working pretty well. Thanks again!
        -mjc
          1/2 inch Aluminum Settings
          Hey all,
          Like Andy said, we have realized a desire for an advanced TIG welding setup guide for our more complex products like the Dynasty, but unfortunatly his comments about available resources is accurate. I did want to start building this thread with member submitted parameters.
          Here is a link to another thread which explains ballance, independant amplitude adjustments and frequency for welding thick aluminum (1/2 and up) with a Dynasty 350.
          http://www.millerwelds.com/resources...ad.php?t=18362
          I hope this helps.
          Miller J. Ryan
          Joe Ryan
          Industrial Marketing Specialist - TIG
          Miller Electric Mfg Co
            Here's the link to the AC TIG: balance control vs. differential current adjustment thread.
            http://www.millerwelds.com/resources...ad.php?t=18449
            Andy
              Originally posted by Miller J. Ryan View Post
              Hey all,
              I hope this helps.
              Joe, your post does not connect to a site.
              Dynasty 350 - My New Baby
              Millermatic 210 Mig with Spoolmate 3035
              Miller Thunderbolt XL 225/150 AC/DC Stick Welder
              Miller Specturm 625 Plasma Cutter
              Speedglas 9100 auto dark helmet
              Jackson auto dark helmet
              18.5 CFM Eagle Compressor
              Oxy/Act
              Horizontal Band Saw
              Dewalt 14" Chop Saw
              7 1/2 Dewalt Angle Grinder
              4 - 4 1/2" Sears Angle Grinders
              1 - 4" Makita Angle Grinder
              2 - IR Die Grinders
              All of which my wife says will be a "he$$ of a garage sale"
                Link
                Leefy,
                After I posted this yesterday, something the cyber world got messed up. I was working with the site admin. to resolve it. She must have worked it out with Andy, because the link that Andy posted is the one I was trying to link to.
                Sorry about the confusion.
                Joe
                Joe Ryan
                  I have been searching for "hidden menu" and not found threads for the older Dynasty 200DX (pre blue lightning)?
                    You might want to open this issue in a unique thread as the 'Dynasty Processes-Set Up' thread should just pertain to documenting settings and so forth.
                    If you go here:
                    http://millerwelds.com/service/ownersmanuals.php
                    and enter your serial number, you'll get the correct owner's manual
                    if you can't find the one that came with the machine when you purchased it.
                    --dseman
                      FATFAB,
                      There are many hidden menus in the 200. Each is excessed by turning the machine off and pressing a series of buttons on the front panel while turning the machine back on. Depending which buttons are pressed and held will bring you to different menu functions.
                      These are all outlined in the manual.
                      Let us know if you still get stuck.
                      Andy
                        Here
                        Seems like the right thread to address this right here....
                        thanks
                        Heiti
                        My Blue Stuff:
                        Dynasty 350DX Tigrunner
                        Millermatic 200
                          Since I'm new to the tig process, I look forward to this thread as being a great asset. If the experienced will start putting the settings of the dynasty for the material they are using, I think it will help all of us dynasty users. Look forward to following and if I ever get good enough, I will add my settings for what works. Now, most of what I could add wouldn't help anyone.
                          Leefy
                          Oxy/Act
                          Horizontal Band Saw
                          Dewalt 14" Chop Saw
                          2 - IR Die Grinders
                            Dynasty 200 dx - late model
                            I have been welding steel stampings,.030 parts and experimenting with pulse on them, It is noisy thats for sure, I have noticed that when starting an arc it will bridge the two pieces easier, and the tungsten point lasts much longer.
                            I am using .040 tungsten for this particular part.
                            I am setting the machine at 60 amps 50 percent 50 cycles and 20 percent background to weld the .030 stamping to a .0625 coupling and get 100% penetration. (average amps are 36)
                            I set it for 34 amps 50 perrcent 50 cycles and 20 percent background to weld the .030 stamping to a .030 spigot fitting on the other end of it, 100% penetration. (average amps are 20)
                            These are fusion welds, no filler, in the event I need it I use .023 mig wire..
                            As far as aiding the penetration with pulse, I havent noticed any difference over DC only. I have talked to others that say it makes a big difference, but I havent seen it yet, but then I am old and a bit dumb........
                            I would like to see a provision on the machine to see what your average amps are when setting up the pulse without striking an arc, this would make changing the percentages much easier without doing the math.
                            mike sr
                              Wondering if one of you computer guys or gals could design a worksheet to be posted here that would have a space by each type of data for entry by us welders. It would simplify what has to be typed by the person providing the information.
                              Thinking something like
                              __________________Type of Welder
                              __________________Type of Material
                              __________________Specification of Material (length/width/thickness)
                              Welder setup
                              __________________Amperage
                              __________________EN
                              __________________EP
                              __________________Balance
                              __________________Frequency
                              ______Y - N____________Pulser used?
                              __________________If Yes Peak T
                              __________________Background
                              __________________Gas type
                              __________________CFH
                              __________________Tungsten Size
                              __________________Tungsten Type
                              _______Y - N___________Gas Lens
                              _____________________Exc.
                              I tried in microsoft excel but couldn't lock the range so you could go through the answer area only. Not smart enough.
                              Anyway, maybe someone could put something on this link and we could fill in the data and attach pics to show the outcome.
                              Oxy/Act
                              Horizontal Band Saw
                              Dewalt 14" Chop Saw
                              2 - IR Die Grinders
