Dynasty Processes-Set Up
This is a sticky topic.
  • #76
    another link or quote
    BC Iron works
    Senior Member
    • #77
      Originally posted by BC Iron works View Post
      another link or quote by brock
      Ed Conley
      MM252
      MM211
      Passport Plus w/Spool Gun
      TA185
      Miller 125c Plasma 120v
      O/A set
      SO 2020 Bender
      You can call me Bacchus
      • #78
        Dynasty 300 DX
        Hi, I would like some help in getting my Dynasty 300DX set up to weld 1/8" aluminum. I have had this unit new for about 5 years and finally have been able to set it up to use. Any help will be appreciated. Thanks
        • #79
          Hey Grizz,
          Welcome to Miller.
          Here is a Tig handbook you can download.
          http://www.millerwelds.com/resources/TIGhandbook/
          I think Chapter 6 has starting parameters to get you started with the Basics.
          Ed Conley
          MM252
          MM211
          TA185
          O/A set
          SO 2020 Bender
          • #80
            Dynasty 300 DX
            Hi Broccoli,
            Thank you very much, I will try that and see what happens. There is a lot of good info here.
            • #81
              Does anybody have any 200DX settings for tacking 3/32" and 1/8" stainless filler rod together to make various things?
              Mostly T-joints (the end coped) or corner joints, various angles.
              I am thinking of a single pulse/spot, to be repeated in other spots if an all-round weld is desired.
              Just a line-it-up-and-hit-the-pedal kind of thing...
              Marcel Bauer
              Senior Member
              "If you build it, they will come!"
              • #82
                Sounds like you need to do alittle trial and error testing. I'd use 1/16" tungsten at least if not .040. You need to go into your hidden menus and lower your start amps for sure.
                Bernard 3500ss water-cooler
                Rockwell vertical mill
                Beverly Shear B-3
                Beverly Shear JR
                Home-made English wheel
                Milwaukee Porta-band
                " Sawz-all
                Tennsmith 36" stomp shear
                Powcon 300st
                • #83
                  Has anyone else noticed on the new dynasty 200's the start parameters go back to the default settings after an extened amount of down time? I didn't use my 200 for about two weeks, and when I powered up and struck an arc, it was a little different. So, I turned it off and powered back up holding the process and amp button's, and it came up on the 3/32nd tungsten size. The last time I used it I had a 1/16th in it that I set the start for. It's not a big deal just wondering if anyone else noticed this?
                  Dynasty 200 DX runner
                  Sync 350 LX
                  XMT 300 w/D74 and roughnecks
                  Hobart 135
                  ESAB PowerCut 875 plasma
                  • #84
                    Mine hasnt done this, but it hasnt been turned off for that long yet. I usually leave it on unless I am gone a few days.
                    78 hours on it so far, 99% tig. I sure like the machine, and no serious error codes yet.
                    Sounds like the battery for the microprocessor could be the problem if it has one.
                    mike sr
                    • #85
                      That sounds like it could be the cause, but just wondering if anyone else noticed this change. Not a big deal, just need to remember to check start parameter when its been off for a week or so.
                      Sync 350 LX
                      Hobart 135
                      • #86
                        I hope this is an acceptable place to ask this question....
                        If I were looking at a used Dyansty 200 DX (serial number LH250xxx) which would indicate a mid to late 2007 pre-Blue Lightning machine.
                        My question is does it still have the adjustable wave AC wave forms without Blue Lightning? My understanding was the Blue Lightning and adjustable waves were both part of the new firmware/HF boards.
                        Is that not correct?
                        Thanks in advance!
                        Chris
                        MM 175
                        Diversion 165
                        • #87
                          New to Forum
                          Hello Everyone
                          I am new to the forum and after reading some of the posts I can see this is going to be a great place to get some hands on information. I have a new to me Miller Dynasty 200 DX and am in the process of getting it hooked up. I have done a quick read through the manual and found that it is somewhat intimidating at first glance. I am sure I can learn a lot from the manual and the information provided by Miller on their site as well as what I can pick up from the forum.
                          Would it be appropriate for me to ask any of the memebers of the forum that own a Dynasty 200 DX that may have perameters that have already been tried and work to share some of this information with me.
                          I would be interested in settings for aluminum,carbon steel and stainless steel from sheetmetal to 1/4" thick. Any help would be greatly appreciated.
                          Thanks
                          Mechanic434
                          • #88
                            Thanks in advance!
                            Chris
                            Well I little more digging on the subject and I believe I found my answer. This thread: http://www.millerwelds.com/resources...Blue+Lightning indicates that The Blue Lightning and AC Waveshapes improvements happened at the same time.
                            MM 175
                            Diversion 165
                            • #89
                              Originally posted by Mechanic434 View Post
                              Hello Everyone
                              Thanks
                              Mechanic434
                              I have several basic settings for you (these are for a Dynasty 200 DX from 2007). I only included the thinner materials because it's generally much harder to weld (for me anyways).
                              .102" Aluminum, fuse weld outside corners
                              3/32" Lanthanated electrode
                              100 amps, Balance 70
                              AC freq. 120 Hz
                              Argon
                              .064" Aluminum, fuse outside corners
                              3/32" Lanthanated
                              69 amps, Bal. 70
                              AC freq. 200 Hz
                              Argon
                              .048" 304 Stainless, fuse INSIDE corners
                              1/16" Thoriated
                              DC 130 peak amps
                              Pulser: 2.0 Hz, 15% peak time, 5 background amps
                              Argon
                              (Very little to no burnthrough with no back purge)
                              .048" 304 Stainless, fuse inside corners
                              1/16" Thoriated
                              DC 30 amps
                              Argon
                              Marcel Bauer
                              Senior Member
                              • #90
                                Dynasty 200 DX Settings
                                Marcel;
                                Thanks Marcel I really appreciate the information on the settings for light gauge Aluminum and Stainless Steel.
                                I have ordered a Bernard 2500 Cooler and a water cooled torch which should arrive next week from the Local Prax Air supplier. I will give these a try once I get set up.
                                I expect I will be asking for additional help as I start using the machine. I have a backlog of home projects that will put the Dynasty 200 DX to the test. It am sure it will make things a whole lot easier then trying to make do with my old AC Buzz Box.
                                Thanks
                                Mechanic 434
