Hi, I just purchased a used miller thunderbolt 225, thinking it was a AC DC welder. It turned out to be a AC constant current only. Is it possible to tig weld this machine or am I stuck with a buzz box only. I'm not sorry I bought it, it welds great.
Dynasty Processes-Set Up
This is a sticky topic.
Wrong thread Bro- this is for the Dynasty Series machines
Just start a new thread so you'll get some hitsEd Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
Originally posted by FATFAB View PostAre their ways to improve the starts on an old 200DX?Ed Conley
MM252
MM211
TA185
O/A set
SO 2020 Bender
KB did write this though..
"I could probably help if you would give a little better explanation of your HF problem. The Dynasty's are sensitive in respect to the tig start parameters so it may be as simple as changing a couple of the settings via hidden menu.
but I still can't find a post on what those changes areEd Conley
MM252
MM211
TA185
O/A set
SO 2020 Bender
My 200DX is having some intermittent issues of starting at lower power levels. Like when I want to just ease the power on as apposed to the arc just POPPING on. This is most apparent while in AC mode
... on that note I did find one where he said to go in to the Hidden menu and reset the Start amps to say 5amps for thin wall AL.Ed Conley
MM252
MM211
TA185
O/A set
SO 2020 Bender
Originally posted by FATFAB View PostNeither can I, I know I read something about adjustments for the older machines.
My 200DX is having some intermittent issues of starting at lower power levels. Like when I want to just ease the power on as apposed to the arc just POPPING on. This is most apparent while in AC modeLast edited by KB Fabrications; 11-21-2009, 06:27 PM.Dynasty 350DX
Dynasty 200DX TigRunner
MM 350P
MM Passport Plus
Spectrum 375 Extreme
08' Trailblazer 302
Dynasty 200 torch
I am looking for a new air torch for a Dynasty 200 - I have conflicting info about whether the Weldcraft LS1712R is compatible with the Dynasty 200.
I can't find any specific info on the Weldcraft site so maybe this torch model is discontinued.
Does anyone have any relevant information as to whether this torch will work or not?
Thanks in advance.
Originally posted by rdenis View PostI am looking for a new air torch for a Dynasty 200 - I have conflicting info about whether the Weldcraft LS1712R is compatible with the Dynasty 200.
Thanks in advance.
You want a remote cable with the 14 pin connection, not a 5 pin connector.
pgLast edited by piniongear; 11-30-2009, 02:48 PM.Dynasty 200 DX_set up on 3 phase
Coolmate 3
MM 251 w/ Spoolmatic 30A
HTP 625 Micro Cut Plasma Cutter
Victor O/A Rig
Bridgeport Mill_3 phase (w/ Acu-Rite 4 axis DRO)
10 inch South Bend Lathe_3 phase
Baldor Double Cup Tool Grinder_3 phase
Baldor 10 inch Buffer
Rockwell 12 inch Disc Sander
Cyclone 2ft X 3ft Bead Blast Cabinet
Quincy 325 2stg- Air Compressor_3 phase
Graymills Built-in Parts Washer
Rockwell/Delta Planer, HD Shaper, Uni-Saw etc.
Converting a Dynasty 200 to a plasma cutter.
I'm sure this subject has been approached before, can anyone direct me to the dicussion.
"is it possible to convert my dynasty 200 to a plasma cutter"? I would like to be able to switch back and forth.
thanks...
Originally posted by kaha View PostI'm sure this subject has been approached before, can anyone direct me to the dicussion.
thanks...Ed Conley
MM252
MM211
TA185
O/A set
SO 2020 Bender
