Dynasty Processes-Set Up
This is a sticky topic.
  • #61
    Hi, I just purchased a used miller thunderbolt 225, thinking it was a AC DC welder. It turned out to be a AC constant current only. Is it possible to tig weld this machine or am I stuck with a buzz box only. I'm not sorry I bought it, it welds great.
    • #62
      Wrong thread Bro- this is for the Dynasty Series machines
      Just start a new thread so you'll get some hits
      Ed Conley
      MM252
      MM211
      Passport Plus w/Spool Gun
      TA185
      Miller 125c Plasma 120v
      O/A set
      SO 2020 Bender
      You can call me Bacchus
      • #63
        Originally posted by FATFAB View Post
        Are their ways to improve the starts on an old 200DX?
        Please BUMP?
        • #64
          I think the answer is "No"; there was a thread when the new model was released and it left folks that had just purchased the "old" model SOL.
          Ed Conley
          MM252
          MM211
          TA185
          O/A set
          SO 2020 Bender
          • #65
            KB did write this though..
            "I could probably help if you would give a little better explanation of your HF problem. The Dynasty's are sensitive in respect to the tig start parameters so it may be as simple as changing a couple of the settings via hidden menu.
            but I still can't find a post on what those changes are
            Ed Conley
            MM252
            MM211
            TA185
            O/A set
            SO 2020 Bender
            • #66
              Neither can I, I know I read something about adjustments for the older machines.
              My 200DX is having some intermittent issues of starting at lower power levels. Like when I want to just ease the power on as apposed to the arc just POPPING on. This is most apparent while in AC mode
              • #67
                ... on that note I did find one where he said to go in to the Hidden menu and reset the Start amps to say 5amps for thin wall AL.
                Ed Conley
                MM252
                MM211
                TA185
                O/A set
                SO 2020 Bender
                • #68
                  What you have to do is go into your start parameter hidden menu. From there you need to set the start amperage to something relatively high like 100 amps. Also, make sure that with AC you have start set to electrode positive. Otherwise, you will struggle to establish the arc. Then, make sure you set the start time to be somewhat proportional to the start amperage. For a 100 amp start, I would begin in the 10 to 20 milliamp range and work your way from there. There is no reason you shouldn't be able to get a good start with the older model 200's. It just takes a little richarding around.
                  KB Fabrications
                  Senior Member
                  Dynasty 350DX
                  Dynasty 200DX TigRunner
                  MM 350P
                  MM Passport Plus
                  Spectrum 375 Extreme
                  08' Trailblazer 302
                  • #69
                    Thanks KB that is what I was looking for.
                    • #70
                      You are welcome my friend.
                      Dynasty 350DX
                      MM 350P
                      MM Passport Plus
                      08' Trailblazer 302
                      • #71
                        Dynasty 200 torch
                        I am looking for a new air torch for a Dynasty 200 - I have conflicting info about whether the Weldcraft LS1712R is compatible with the Dynasty 200.
                        I can't find any specific info on the Weldcraft site so maybe this torch model is discontinued.
                        Does anyone have any relevant information as to whether this torch will work or not?
                        Thanks in advance.
                        • #72
                          Thanks in advance.
                          It should work fine. The LS1712R is a 12ft cable (rubber) and a 17 size torch. Here is a link to a seller....http://www.uswelders.com/product_det...product_id=307
                          You want a remote cable with the 14 pin connection, not a 5 pin connector.
                          pg
                          piniongear
                          Senior Member
                          Dynasty 200 DX_set up on 3 phase
                          Coolmate 3
                          MM 251 w/ Spoolmatic 30A
                          HTP 625 Micro Cut Plasma Cutter
                          Victor O/A Rig
                          Bridgeport Mill_3 phase (w/ Acu-Rite 4 axis DRO)
                          10 inch South Bend Lathe_3 phase
                          Baldor Double Cup Tool Grinder_3 phase
                          Baldor 10 inch Buffer
                          Rockwell 12 inch Disc Sander
                          Cyclone 2ft X 3ft Bead Blast Cabinet
                          Quincy 325 2stg- Air Compressor_3 phase
                          Graymills Built-in Parts Washer
                          Rockwell/Delta Planer, HD Shaper, Uni-Saw etc.
                          • #73
                            Thanks PG for the quick reply - awesome website here!
                            • #74
                              Converting a Dynasty 200 to a plasma cutter.
                              I'm sure this subject has been approached before, can anyone direct me to the dicussion.
                              "is it possible to convert my dynasty 200 to a plasma cutter"? I would like to be able to switch back and forth.
                              thanks...
                              • #75
                                thanks...
                                Nope
                                Ed Conley
                                MM252
                                MM211
                                TA185
                                O/A set
                                SO 2020 Bender
