Dynasty Processes-Set Up
This is a sticky topic.
  • Originally posted by paulrbrown View Post
    Pictures would help, along with settings.....100 amps is enough to melt about anything......very strange.....looking forward to your response
    Weird! Yes, pix & setting would help.
    I assume, DC, no pulse, good ground, clean. Try some stringers on another piece of known mild steel. Should be as easy as it gets.
    Let us know. I'm very curious.
    : Keep Learning :
    You never know what you don't know.
    ________________
    MM180 autoset
    Hypertherm Powermax 45
    • Problem Solved
      So when I got back to the shop some of the employees made off with the angle iron I was using, I grabbed another couple pieces and cleaned them good with a flap disc and ground directly to the work (was grounding to welding table before). Problems solved! So I'm guessing it was a bad ground, but now I've been able to run at 120-175 amps (I'm light on the pedal so I found that if I compensate by running a higher ceiling it makes it easier) without any issues. I've been finding that SS and AL are much more consistent, with steel there's more "variables" as you weld, other than that I've had no issues at all! Lovin the new Dynasty!
      • Spot setup on Dynasty 200DX question
        The manual section "6-3 G Spot Control Operation" shows a graph where the current jumps up to the "Timed Spot Weld Amps", stays there for some period of time and then drops to 0. It indicates to Push & Hold Trigger to start and then to Release Trigger After Sport Time is Done. I have set my machine to this mode as follows:
        - reset to factory defaults
        - set main amps to 120 (for this test)
        - enter Advanced menu by pressing Main Amps and Gas/Dig buttons at the same time
        - press the Gas/Dig to toggle to the rt option on the menu
        - turn the amp adjustment knob until the machine displays rt SPO
        - exit Advanced menu by pressing Main Amps and Gas/Dig buttons at the same time
        - set Output to RMT 2T HOLD
        I have the machine connected to a foot pedal which I am using for a switch. If I depress the foot pedal just enough to close the switch I observe a full 120 amp blast of current which lasts for about 1 second. It then stops even though I am still depressing the pedal. So far, so good.
        However, the manual says this is a "Timed" spot weld. Can I change the amount of time for which the arc is maintained? If so, how?
        I read a post somewhere in this 19 page sticky which indicated that the spot time could be changed by pushing in on the amp control knob. That does nothing on this Dynasty 200. Perhaps the post referred to another sort of machine. Search only takes me to page 1 of this thread and I don't feel like looking through all 19 pages again.
        Thanks,
        Ken
        • Originally posted by taylorkh View Post
          Thanks,
          Ken
          section 6-6 of the manual
          "Turn encoder to turn Spot on and off. Once on exist set-up and press Amperage control switch pad twice and turn encoder to set spot time."
          There might be a time limit in which you have to press the Amperage switch pad twice to activate the Spot Time
          Ed Conley
          MM252
          MM211
          Passport Plus w/Spool Gun
          TA185
          Miller 125c Plasma 120v
          O/A set
          SO 2020 Bender
          You can call me Bacchus
          • Thanks Broccoli1,
            Section 6-6 in MY manual (dated 2012-10) describes Stick Open-Circuit Voltage selection.
            I did a search withing the manual pdf for "set spot time" and found it in section 5-14! It states
            Select Spot function according to Section 6-3G.
            Set spot parameters as follows: Press Amperage switch pad once (meter A LED turns on) and turn Encoder to set spot amperage. Press Amperage switch pad again, (meter S LED lights) and turn Encoder to set spot time (.1−25 seconds). Factory default setting is 1 second.
            Application: To provide a timed weld. Used for tacking, and thin sheet joining.
            I guess I am supposed to read the manual backwards as well as forwards. This is the most disorganized manual I have ever seen. I would have expected at least a cross reference from 6-3 G back to 5-14.
            Well at least I have some directions to go by. I will give it a try after supper. And document the exact steps. I don't think pressing the Amperage switch alone exits the advanced settings mode so perhaps it is putting the machine in some other hidden mode.
            Thanks again,
            Ken
            • OK, so here is MY Timed Spot setup instruction for Dynasty 200 DX welders covered by the 2010-10 manual. My machine was manufactured in 2011 by the serial number. Machines of any other vintage - who knows...
              Notes: I am starting these instructions from the factory default machine settings. I suspect that many custom configurations can be set concurrently but I have not explored the unintended consequences between settings (yet).
              - This document should be applicable in part to the Dynasty 350 and 700 but I don't have access to one of these to test at the moment.
              - The button below the "Encoder Control" knob is labeled A MAIN/PEAK on the 200 and A on the 350/700. I will call it the AMP button - less typing
              - The ADJUST button on the 200 is labeled GAS/DIG on the 350/700.
              - Press means to press and release the button. I will explicitly indicate the need to press and HOLD a button.
              1 - Power on the machine and immediately press and hold the PROCESS, OUTPUT and ADJUST buttons. Release the buttons when the display shows --- 150. The machine is now at factory default. DC TIG, HF Impulse, STD RMT at 150 main amps.
              2 - Press the AMP button and the ADJUST button at the same time. The machine is now ready to set advanced features.
              3 - Set the tungsten size using the Encoder knob. This controls the starting parameters for the machine. It is applicable to ALL modes of TIG operation.
              4 - Press the ADJUST button until rt 2t is displayed.
              5 - Turn the Encoder knob until rt SPO is displayed. The machine is now set to spot mode.
              6 - Press the AMP and ADJUST buttons at the same time. The machine is now back in operating mode (out of "set advanced features" mode)
              7 - Press the OUTPUT button to set the machine to RMT 2T HOLD. This setting should really be called "run the advanced mode I just finished setting up." rt SPO will display BRIEFLY. The display will then return to --- 150.
              8 - Set the desired spot welding amps using the Encoder control.
              Note: The SPOT amps setting is the same as the peak amps setting in the RMP STD output mode. If you change the amps in RMT STD and then switch back to SPOT mode the RMT STD amps are used for SPOT.
              9 - Press the AMP button. The display will show SPO 1.0. This indicates that the spot time is set to 1 second.
              10 - Adjust the spot time as desired using the Encoder knob. This value will be remembered.
              11 - Press the AMP button to save the value. The machine is now ready to spot weld.
              But it gets better...
              12 - Press the POLARITY button to switch the machine to AC. Observer that the displayed amps may change. The amps value displayed is the default value for AC amps.
              13 - Press the AMP button. The machine will display SPO 1.0 again. The machine saves a separate spot time for AC and DC.
              14 - Turn the encoder control to set the desired AC spot time.
              15 - Press the AMP button to save the setting.
              • Bumping Anodized Pipe with 200DX
                Does anyone weld anodized pipe with a Dynasty 200? I have a dynasty 300, but I'm looking for a mobile solution to plug into TB 302. I love my 300, just not sure if the 200 has the guts to bump weld anodized pipe. Seems like the amps would need to be run at max, and the duty cycle limited to 20%.
                The other option is high freq box on trailblazer.
                I would appreciate any input!
                -Mark
                Mark Thompson
                Arc Tech Welding
                • Dynasty200 Question.
                  Can the pulse feature be used on AC tig process, and is it effective? This is on a dynasty200 DX
                  • Originally posted by khs1241 View Post
                    What are you trying to accomplish? I use it on casting repair to agitate the puddle . . . helps float out the contaminants. It might not be as useful on the 200 DX as it reduces effective maximum current.
                    Dynasty 300DX
                    MM350P
                    Hobart Handler 120
                    Smith LW7, MW1, AW1
                    Smith AR/He Mixer
                    • DYnasty Processes-set up
                      Was utilizing the website admin. to resolve it. She will need to have worked that out using Andy, considering that the link in which Andy posted may be the one My spouse and i was trying to link for you to.
                      engine optimization seo
                        Pulse on AC is good for getting a nice consistent lap weld, especially on 1/8" and thinner aluminum. Keeps the heat input lower and the arc nice and focused. I usually run 300 pps, 33% background, 33% peak time and 225 HZ. Welds very nicely.
                        • Dynast Pulse
                          As a newer user to the Dynasty lineup and newer to TIG welding overall I've found the pulse settings extremely helpful with heat control. I use it with new materials that are thin as the guys stated above, pps range from 1 to 30, sometimes up to 50, but I havent found much benefit for me above 50, 33% across the board for the rest with freq from 125-225 depending on how wide or deep I'm wanting to go with it, however when using thicker materials I end up around 50% ontime and 40% background, freq from 95-225 depending, I've done a lot of repair on older Aluminum snowmobile trailers, when you can't clean inside the tube your welding its hard to not end up with porosity as you pound in the heat, it'll leach the junk through from the inside if you get it too hot. Even with the pulse it's a battle on these, a lot of people won't touch them for this reason, but with pulse I've have great success and happy customers. When doing fusion welds I found that between 1-6 PPS with slightly higher than 33% worked best for me and gave me the best look to the welds with filler rod in use I'd be more in the 15-30 pps and the percentages mentioned above.
                          I love my Dynasty 350, I wouldn't give it up for anything, I just got a push pull for my MM 252 so I'm anxious to give that a try and see how it works, but my dynasty is a beast with AL.
                          • Ls1712r torch compatability for dynasty 200dx
                            Originally posted by rdenis View Post
                            i am looking for a new air torch for a dynasty 200 - i have conflicting info about whether the weldcraft ls1712r is compatible with the dynasty 200.
                            I can't find any specific info on the weldcraft site so maybe this torch model is discontinued.
                            Does anyone have any relevant information as to whether this torch will work or not?
                            Thanks in advance.
                            i ended up with your problem about this and i went ahead and bought 1st one and couldnt get the plug in to work on my new dynasty so i sent it back for another and had same problem, so i looked it over real good and noticed the grove in the head was offset to much and if i forced it surely would have bent pins si i took and small points file and opened it up a touch , cause all you really need is for pins to match, it works fine now, if i can be of any other let me know , i hope this helps anyone else before buying this torch. I might have just got a bad batch, beenabean
                            HOBART TIGMATE/DYNASTY 200DX/LINCOLN SP 180T/ HARRIS OX/ACETELENE
                            • What current does your Dynasty display?
                              What current does your Dynasty display when using the pulse feature? I generally set the current higher than necessary and use the pedal to adjust it. I don't often look at the panel display . . . it doesn't display long enough . . . but I wanted to set the max current on a project and use a full pedal to make a consistent bead.
                              Setup:
                              Dynasty 300 DX
                              DC
                              panel - 100 amps
                              full pedal
                              frequency - 40 Hz
                              peak current time - 40%
                              background current - 40%
                              Machine displays 64 amps . . . so it displays average current.
                              40% x 100 amps = 40
                              60% x 40 amps = 24
                              total = 64
                              Dynasty 300DX
                              MM350P
                              Hobart Handler 120
                              Smith LW7, MW1, AW1
                              Smith AR/He Mixer
                              • Guys,
                                i will be doing some research this weekend, but can you give me some starting parameters for the dynasty 350 on welding thick aluminum, 5/8" to 3/8" and 5/8" to 3?16" thick ?
                                substrate is 6061 and will be using 3/32 4043 filler, and need a 1/4", .250" weld bead.
                                thanks guys... we are currently using a syncrowave 350 and the local miller rep is lending us the dynasty for a week to see how we like it.
                                thanks
                                Syncrowave® 200
                                Lincoln AC/DC 225/125
                                Lincoln Weld Pak 100 wire feed
