I doubt this one exists but it sure would be cool if you could plug a trailblazer into a 220v receptacle and use it in your shop without the engine. I dont see why it would not be a possibility as it is essentially a XMT inverter powered by a generator. Can this be done now or do I have to wait for the fine folks at miller to develop this function.
Can Engine-Driven Welder Plug In?
The Trailblazer is not anywhere near an inverter. You might be thinking of the PipePro. It has the XMT engine and it CAN be used on shore power with the shore power transfer kit.
The Trailblazer is an electronic field controlled 3ph weld output machine. The generator is required for it to run.
Maybe in the future a "Dynasty" engine drive would be cool!
Andy
I might be wrong,but I think it's the renegade that you can do that with...that's the engine driven mig/flux-core machine...no stick welding.Miller Syncrowave 180
Miller 211 w/ spool-gun
Lincoln AC/DC buzzbox
Cutmaster 38 plasma
Oxy/Acet torch
DeWalt Multi-Cutter
Fiber Metal Helmets(old school)
Enough Snap-On to be a dealer.
"Plugged In"
Actually, chrisa7164 is 1/2 right. The new Renegade 180 is an industry-first integrated wire welder/generator WITH Dual Power. You can weld from 230V shop power or from 1 cylinder Kohler 10 hp engine.
The PipePro 304 has an OPTIONAL dual power feature which operates from 230V shop power single or 3-phase or the Kubota 26 hp diesel.
Dave"Bonne journe'e mes amis"
Well now I believe it is high time to upgrade the Renegade into the 211 model.
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
I suppose it would be possible to drive that engine with a outside electric motor & shaft though it would have to be in perfect balance.
You would also have to pull your spark plugs and put in air one way check valves and use the engine as an air compressor. You would have to have a fuel and spark shut off. Hmmmm. Still might be too much torque on the flywheel
Originally posted by walker View PostIt would be even cooler if you could start it on the engine then plug the shore power cord into the 230v outlet on the front of the machine.at home:
2008 Suitcase 12RC
Spoolmatic 30A
WC-24
2009 Dynasty 200DX
2000 XMT 304
Sold:MM130XP
Sold:MM 251
Sold:CST 280
at work:
Invision 350MP
Dynasty 350
Millermatic 350P
at home:
2008 Suitcase 12RC
Spoolmatic 30A
WC-24
2009 Dynasty 200DX
2000 XMT 304
Sold:MM130XP
Sold:MM 251
Sold:CST 280
at work:
Invision 350MP
Dynasty 350
Millermatic 350P
Originally posted by walker View PostIt would be even cooler if you could start it on the engine then plug the shore power cord into the 230v outlet on the front of the machine.Millermatic350P/Python, MillermaticReach/Q300
Millermatic175
MillermaticPassport/Q300
HTP MIG200
PowCon 300SM, MK Cobramatic
DialarcHF, Radiator-1
Hypertherm PowerMax 380
Purox oxy/ace
Jackson EQC
-F350 CrewCab 4x4
-LoadNGo utility bed
-Bobcat 250NT
-PassportPlus/Q300
-XMT304/Optima/Spoolmatic15A
-Suitcase8RC/Q400
-Suitcase12RC/Q300
-Smith oxy/propane
-Jackson EQC
