Twin Carbon Arc Torch with Inverter??
  • Twin Carbon Arc Torch with Inverter??
    Some time ago, I sold my old Thunderbolt buzz box. Occasionally, I would use a twin carbon arc torch for heating seized bolts, or pulling gears off a taper.
    My question is this: Is it safe for an Inverter (Dynasty 200 DX), to use a twin carbon arc torch? Do you think there is a possibility that a Transformer is more durable for the twin carbon arc process? I would much rather just buy another old buzz box than nuke the Dynasty!
    Thanks for any input!
    Have a good one!
    ~Ian
    :~ATTITUDE MAKES THE DIFFERENCE!!!:
    Have a good one!
    ~Ian
    Not likely. Some inverters are designed to accomodate the carbon arc's electrical appearance as a dead short, but the dynasty 200 to my knowledge is not one of them. The XMT series are capable, however.
    --dseman
      You're not pulling a lot of amps anyway, are you?
      Meanwhile, I like the irony, using the latest tech power supply to run a torch everybody else seems to have given up for dead (I use CA-T also, but not on an inverter welder . . . yet).
        Dynasty will likely see a dead short and either go poof, or turn itself off.
        Pick one....
          Back to the buzz box
          Hey guys, thanks for the replies. I am just going to find another old buzz box to run that old twin carbon arc torch. Sometimes those old torches make short work out of seized up nuts and bolts that I constantly fight on boats.
          Thanks!
          ~Ian
            Boats...that explains it! Nothing better to test your metal.
            Danny
