92 dodge welding truck
  • 92 dodge welding truck
    well guys, I finally built a welding truck. Thought I would share some pics. I was always lookin for ideas when I was building this. Hope you enjoy. any comments welcome.
    What I have:
    1992 dodge cummins
    9' flatbed w/ goose neck hitch
    2 under bed boxes
    1 custom built aluminum rat pack under welder
    1 Trail blazer 302
    1 craftsman 5 drawer box
    1 bed side white tool box
    1 hitch mount lift crane
    1 bed mounted 8" vise
    1 custom build resessed torch set holder.
    1 welding lead holder rollers.
    1 set of air bags to hold it all
    DAY WELDING LLc
    1992 dodge cummins welding truck
    trailblazer 302
    2004 cummins welding truck.
    old SA 200
    Victor torch set
    Lots of crazy ideas!!
    Off Road Welding Services
    I can see why you would need air bags. Your truck looks like you can get the job done. What are you planning on lifting with the crane.? Would it be better on one of the rear corners,? You could weld a socket flush with the bed so you could remove it and still use the truck to haul a goose neck trailer.
    You done a nice job on the truck bed..
    Bob
      You can't go wrong with that old first generation Dodge, It will run forever with a little care.
      I have one. I'm still working out of the original pickup bed. Bought it new in 92 has 295,000 miles and all I've done is replace the inj. pump and it still wont use any oil between changes and if I drive it easy will get 21 mpg.
      Trailblazer 302
      Lincoln SP-135-T
      Hobart Stickmate AC/DC
      Smith torch
      Spoolmatic 30A
        urch55
        That socket is a good idea for the crane!! I actually use it quite a bit. I do Irrigation pipe fitting and welding. a lot of the time I need the extra reach of the crane out the back of the truck so i can reach down in a trench without the truck so close to the edge. But, that is one reason also I had it on the hitch is because i was concerned about pulling a goose neck. I may have to mount it up there anyways. It would be more out of the way.
        DAY WELDING LLc
        trailblazer 302
        old SA 200
        Victor torch set
          I hope i can get 21 mpg out of this one. It was suped up before I bought it,and now has a 6speed Nv5600 tranny in it. i only got 16 mpg doing 65 when i first got it. it has 80hp injectors too, so i put a new worked over turbo on it from a 2nd generation. it bolted up, no problem. only $250. it burns a lot cleaner and runs up to speed easier. so hopefully i can catch up to your mileage. I ran out of the back of my 04 cummins b4 i bought this truck. it was rough. so thats y i bought this and did the flatbed. Its such a relief. lol.
          DAY WELDING LLc
          trailblazer 302
          old SA 200
          Victor torch set
            The one I have has the 3.42 gears in it and that helps a lot. A lot of them have the 4.10 or 4.11 cant remember which Dodge uses, if you have that you might be getting about all you can get.
            Mine just got started life as my welding truck after I retired, before that it was a daily driver.
            When I replaced the pump on mine I found a used one but it had been turned way up, but as long as I feather foot it I can still get the mileage that it always did. But if I put my foot in it all bets on mileage are off but I can sure put out a lot of smoke.
            Trailblazer 302
            Lincoln SP-135-T
            Smith torch
            Spoolmatic 30A
              lol. nice. that turbo out of the 2nd generation i put in sure helped with my super smoke problem. still throws it out if i drop the hammer. so, i feel dumb for having to ask, but where do i look to see what ratio i have? I have been wondering. I think its the 4.10, because it doesn't run out every gear except for 5 and 6 very far. you should come join up at www.dieseltruckresource.com they have all generations of dodges over there. I have been getting good advice from them.
              DAY WELDING LLc
              trailblazer 302
              old SA 200
              Victor torch set
                Ratio Rite
                Three ways to tell what ratio you have, first is there a tag on the pumkin some where,? Second count how many turns the axle turns to one of the drive shaft, not the tire/wheel. Third pull the cover off and the ratio is stamped on the ring gear.
                  Gear ratios for the first gen CTD 4x4's:
                  Pre-91 with non overdrive 727 auto = 3.07 (oddball because it uses a dana 61 front axle instead of dana 60)
                  91.5+ OD auto = 3.54 or 4.10
                  5 speeds = 3.54 or 4.10
                  2007 Miller Dynasty 200 DX
                  2005 Miller Passport 180
                    What I have:
                    1992 dodge cummins
                    2 under bed boxes
                    1 Trail blazer 302
                    Hay Day Welding, Nice rig! Thought i would say HI to a local! I run a small portable welding biz in Buhl ID!
                    Miller Trailblazer 302
                    Miller 12 RC wire feeder
                    Miller HF 251D-1
                    Miller 175 wire feed
                      simple But it should work.
