hello new member with a few questions
  • hello new member with a few questions
    well i have been pipe welding for about five years know mostly i have been standing flat footed on the ground and rolling out my welds without a whole lot of positions lucky me. well know the man that tought me a lot about how to and what not to do has been lost with all the retirement things to do list he was always talking about so i was wondering if there was anyone with some advice on how to make the bottom look good on some 10" welds that are giving me some trouble i have got the root with no problems but the filler looks like im running to hot or that im streching out my arc im not slowing dow an and have tryed some advice from a friend that said weld with the world but i still looks pretty bad lots of under cut looking for some advice thank you my rod burning brothers and sisters
    what rod are you using, and what size.
    sigpic2007 dodge 3500 cummins
      Rod angle is very important. Also not having correct heat range,could be giving you the undercutting.
      Lincoln Idealarc 250
      Millermatic 211
      Spoolmate 100
      Arnold
        ....and what type and schedule of pipe?
        2- XMT's 350 cc/cv
        1- Blue star 185
        1- BOBCAT 250
        1- TRAILBLAZER 302
        1- MILLER DVI
        2- PASSPORT PLUS
        1- DYNASTY 200 DX
        1- DYNASTY 280 DX
        1- MAXSTAR 150 STL
        1- HF-251 BOX
        1- S-74D
        1- S-75DXA
        2- 12-RC SUITCASES
        1- 8-VS SUITCASE
        2- 30 A SPOOLGUNS
          assuming you're weaving the rod, you gotta get the timing and steps just right, pause on the sides, not too slow through the middle but don't outrun the puddle either. on the bottom half you'll want to make bigger steps up. takes practice and constantly evaluating your welds. i assume your speaking of the 5g position? as you come up around the pipe the timing and steps change along with rod angle. takes lots of practice and a good clean hood to recognize what the puddle is telling you. if you see the puddle bulging out or in a V shape you're going either too slow, too narrow, too tight of stepping, too hot, too long or too short of pauses, or a combination of those. as always, read the puddle.
            Hello to everyone, pls help, i'm very confused regarding the definition of plater welder, is it there a big difference or welding process plater welder and plate welder?
              "Plater/Welder"
              Description used in the United Kingdom and Norwegian/Finnish Countries
              Dave
              "Bonne journe'e mes amis"
                You know the old saying.........
                If you want the bottom to look like the top.....F**C up the top!
                Miller Syncrowave 200
                Homemade Water Cooler
                130XP MIG
                Spectrum 375
                60 year old Logan Lathe
                Select Machine and Tool Mill
