Bought new Miller, have questions
  • Bought new Miller, have questions
    Just bought new Miller Passport Plus and have two questions. Does Miller have another dual voltage adapter that has 3 prongs in the shape of a range plug for 230 volts? All of my outlets are wired that way.
    Second, when I start welding wire starts slow for a second and then speeds up... why is that?
    Check your rollers.
    Brian C.
    Turbobrian Fabrication LLc.
    Miller D165
    Miller 140
    Miller Digital Elite
      Jam up Jelly Tight
      I too use the 50 amp range plug I make up my own adapters/extension cords.. On your wire feed increase the tension but don't over tighten it other wise it will flatten the wire and cause more problems. also make sure your line is as straight as possable... Bob
        I will check rollers, it was just so consistent I thought it might have been a new feature.
        On the plug, I am surprised Miller doesn't offer an adapter in the range plug style as I had to have paid pretty nickle for machine and then cobble something together???
          Checking rollers won't help Passport is designed that way- run in time.
          Took me a while to get used to.
          Ed Conley
          MM252
          MM211
          Passport Plus w/Spool Gun
          TA185
          Miller 125c Plasma 120v
          O/A set
          SO 2020 Bender
          You can call me Bacchus
            They no longer offer the 3-wire Range Plug as part of the MVP set-
            'splained to me that if the receptacle is fed by a Sub Panel then there is not a "Code" ground connection.
            Ed Conley
            MM252
            MM211
            TA185
            O/A set
            SO 2020 Bender
              If you are bothering yourself with welding then I wouldn't consider making a three wire connection to be a "cobbled" thing.
              it's just three wires and why use an adpater anyway
              MillerMatic 140 Auto-Set
                because ya need to plug in a 6-50p to a 10-50R- only way to do it is WITH an adapter Pigtail
                Ed Conley
                MM252
                MM211
                TA185
                O/A set
                SO 2020 Bender
                  You could check with your local welding supplier to see if they make up adaptor cords. I ran into this problem last week when I took one of my machines into town to do some work. I priced buying the parts to make up an adaptor from both Lowes and Home Depot and didn't like the quality of what they were selling. I checked with Alamo Welding Supply in Austin and they made me up a really high quality adaptor cord for about what I would have spent at the store for cheap chinese garbage parts.
                    I too, was stalled by the wrong cord end, so I chopped it off and installed one that matched my receps. Got it at Lowes for $10.
                    prolly voids the warranty tho.
                    Syncrowave 250 DX
                    MillerMatic 212
                    Hypertherm plaz
                    Coors light on tap
                      Barnage,
                      You can't do this with the Passport. It's a multi-voltage machine and the cord wires don't correspond to normal single voltage type machines such as your 212.
                      The chance of mis-wiring the machine and blowing it up is too high.
                      Andy
                        "Home On The Range"
                        Honestly, how many people weld in their kitchen?
                        "Bonne journe'e mes amis"
                          Originally posted by ASKANDY View Post
                          Barnage,
                          Andy
                          I know you know what you're talking about, so maybe you could explain that a bit further, Andy.
                          IIRC, it has four wires in its adapting bits. Is that where the selection is made for 120 or 240 volts, and it's not an automatic switching feature inside the machine?
                          I don't have my Passport anymore, but I remember it took me some time to get used to the run-in feature on the wire speed, too. Worked fine, of course; it was just the first machine I owned that was advanced enough to have it.
                            Dave- yee have little faith- they walk among us
                            Ed Conley
                            MM252
                            MM211
                            TA185
                            O/A set
                            SO 2020 Bender
                              Ed Conley
                              MM252
                              MM211
                              TA185
                              O/A set
                              SO 2020 Bender
