350 LX Trouble codes
  • 350 LX Trouble codes
    Hi, Any one have any experience dealing with syncrowave repairs? I have a trouble code that reads, HLP --2. Thanks for any help.
    Help 2 is usually an open thermostat in the trasformer or the stabilizer coil.
    It could also be the wires going to either of those got pulled out or have a loose connection giving that fault code.
    Andy
      Help 2 code is the transformer thermal protection. Either you have a bad thermostat or your board is smoked. Open the case and pull your board out and make sure that you don't have any burn spots on the back of it where the thermostat wiring harness plugs into the board. Also check to see if the thermostat is open using a meter.
        Pull and reinsert your molex connectors, if you happen to have translucent silicon grease (Dielectric electronics quality), coat your plugs with it before reinsertion. Your problem may just go away.
        Don't put this dielectric grease on any ribbon cables though.
