I'm having a problem with my Syncrowave 180, anybody ever seen this?
  • I'm having a problem with my Syncrowave 180, anybody ever seen this?
    I've been the proud owner of my Syncrowave 180 for 4 or 5 years now and I ran into trouble with it. I was welding some 1/4" steel @ about 120 amps, nothing too demanding. I welded off and on for about 10 minutes and then walked away from it for a while. I came back to it and that's when the trouble started.
    When I hit the foot pedal I get absolutely nothing. No arc, no gas. When I switch the machine from TIG to Stick (but with the TIG torch still hooked up), I get gas flow while I'm switching it, and when it is switched I can scratch an arc with the tungsten.
    I checked all the cable connections, everything is good. I powered down the welder and unplugged it for a minute or so, plugged it back in and that didn't help.
    I thought it might be the foot pedal. I tore it apart, it is a 5 wire pedal and there are two components in it. A limit switch and a 1K Ohm potentiometer. I checked the limit switch for continuity, it is good. I checked the resistance on the pot, it changes smoothly from 0-1K ohms across wires 1 and 2, and it changes smoothly from 1K-0 ohms across wires 2 and 3. It seems like this is right.
    Anybody ever have a similar problem or have any other ideas? My next step is to investigate inside of the welder but I don't really know what to look for.
    That "Limit switch" is the relay that turns the machines contactor and gas solinoid on and off. It may need to be adjusted if your not hereing the Click when you press the pedal.
      My pedal could be different, it is not a relay in the pedal. It is a limit switch.
      It looks similar to this one: http://www.alibaba.com/sellinglead-g...showimage.html
      It has two wires going to it and they are in the NC position.
      I can hear it clicking when the pedal is assembled, so it is switching. That does help that I now know that it controls the contactor and gas solenoid, that's a good place to start when I tear into it.
        We call them "micro switch" over here.
        Never heard of them as being a relay.
        But I guess components are referred to by different names depending on which country you are in.
        It may be clicking but is it actually working? as in triggering
        Have you metered the cable back to the machine?
        Checked plug front and back
          The name "Micro Switch" is actually a company owned by Honeywell. There are various manufacturers of these small "mechanical relays".
          We all say micro switch, as they were the first to introduce them.
            I have checked the switch in the pedal and it works as it should. Once again, it is not a relay. A relay is an electrical switch that is controlled by an additional circuit. Relays allow you to switch a high current circuit with a low current circuit. They require at least 4 wires. This switch has two wires, one input and one output. My guess is that there is a relay in the welder that this switch controls. Anybody else have any info on this? I'm really only looking for someone to point me in the right direction, or maybe give me a few possible scenarios of what I might find when I get inside the welder.
              Even welders have a thorn in the flesh
              Hey there cycle.. You said you checked the switches in the foot pedal and you found 5 wires. you checked 1 & 2 and you checked 2&3 did you ever unplug the pedal and check all the wires from plug to pedal for continuity.? plus check the male and female pins in the plug/socket.. It's probably some thing real simple and it was over looked. You will fine the cause take your time.... Bob
                As a matter of interest would you class a voltage switch as a mechanical relay?
                  Releco relays and others have a test button that manually closes 2 poles in the relay. Is this a switch?
                    If possible find a good working torch , plug it in to your 180, if it works than you know what to do. dont tear it into machine if you dont have to. I'm sorry if somebody already mentioned that.
                      torch? i meant good working foot/finger control.
                        No, it is a relay
                        A micro switch is never referred to as a relay nor is a torch trigger over here.
                        So a voltage switch is referred to as a relay by you guys over there?
                          Originally posted by Jake SS View Post
                          No, it is a relay
                          Not really. A relay is sometimes referred to as a "electro-mechanical switch" but I've never heard of a switch being referred to as a relay and I've been design and building control systems and automation equipment for about 37 years, not that I couldn't have missed something.
                            It is a micro switch and not a relay. A switch needs physical force to activate it. A relay has contacts like a switch but also a actuator such as an electrical solenoid to activate the switch and can be controlled remotely.
                            Now put a solenoid on your switch and you have a relay.
                            Nick
                            Miller 252 Mig
                            Miller Cricket XL
                            Millermatic 150 Mig
                            Miller Syncrowave 200 Tig
                            2-O/A outfits
                            Jet Lathe and Mill
                            Jet 7x12 horz/vert band saw
                            DeWalt Multi Cutter metal saw
                            Century 50 Amp Plasma Cutter
                            Propane Forge
                            60" X 60" router/plasma table
                              No, it is a relay
                              Nope the electrical portion of the Releco is a relay, the mechanical test push button is a switch.
                              Same as a positioner table hitting an magnetic switch and reversing itself, no physical force really, just a polarity pickup, or even an electric eye picks up a discrepancy in its field of vision, or encoders that is also a switch for wave form production.
                              An IGBT is a ultra fast switch, as are transistors, mosfets, scrs and such, all electrical switches.
                              Its all the way you look at the problem to get the job done.
