Here's a finshed product photo
Thanx again
Tig welding aluminum setup help
Thanx For The Feedback Workn good today.
Thank you for all the advice.
Extra cleaning of has helped greatly.
Cer. tungsten also has helped.
However, gassing of the jig material. Great reply post.
Part of the jig has some spacers made of MDS. (glued wood particle)
After heated, a little smoldering. Done.
Rejigging to steel surface and spacers.
Thanks again to all for great info.
Originally posted by Jerm View PostI have used 3/32 tungsten on material up to 3/4. It requires some pre-heating. I have always used a balled end on the tungsten for aluminum. Miller has a new tungsten out now that can be used with a point on it. Not sure what it's made of but the color code is orange. It can be used on steel and aluminum
I have never use anything over 3/32" and welded 1/2" plate with it on a lincoln machine. My Sync 200 doesn't like aluminum over 3/16"
Is the channel anodized??
Try doing everything by the book, eliminate any possible chances of contamination, Sand joints down clean with acetone, use clean rags and stainless brushes, stack all the variables in you favor and check for proper gas flow from you torch. Is your gas lens clogged?? How clean is the cup??
Is your gas line leaking?? Is it pure argon?? Or is it a mig bottle?
I am not an expert and will be asking for help soon myself...but doesnt 3/32 seem too small an electrode for 1/4" aluminum? (edit went back and read the second part was only 1/16th sorry)
plus everything I have read is to not make a point on the electrode for aluminum...you want a blunt or balled end.
also I read a website that had a guy giving several pages of tips for welding..and he said he used 2% thoriated all the time for welding aluminum( which went against what I was taught)...but he acknowleged it wasnt common, but said he gets better welds using it on aluminum.
bobLast edited by dvice; 05-08-2009, 09:58 AM.
I aggree with griff. I have never used 2% on aluminum. It can be used on low heat applications, on thinner material. Are you using pure argon?
Originally posted by Bluedog View PostMy beads aren't flowing today. Some constructive advice needed.
The project is using 1/4"x 2/1/2" 6061 and 1/16" th. 1 1/2" channel, which is being fillet welded. Filler is 4043, and both flat and many verticle welds are required.
Welded a test piece flat, and by the second weld, a clean bead was successful.
Now, welding the jigged assy. and am experiencing numerous intermittant conditions.
Arc control, when obtained puddle isn't always visible. When it does puddle, seems i'm backing off to add filler. Or filler will ball.
Bead width is wider than test, and not as clean.
Intermittant tungsten contam and soot.
When tacking, some take 2 secs, and other, well is it friday yet?
Equip and settings
3/32 thor tungs to a point trying to keep bead small so no distorion to visible side.
9-11 Balance test liked 10
20 cfm argon
HF 85 should it be higher? 100 max
240-260 Amps test welded @ 210
Funny enough, i've welded all kinds of dissimilar steel with rust, pickling, zinc, aluminized, and a little clean aluminum is workin me!
It is hard to tell in the picture, maybe the preflow on the gas, a bit of oil on the end of the material, kind of shooting in the dark. Usually when I get soot it means the tungsten has been dipped, however arcing somewhere else may cause this as well as in a bad connection.
mike sr
Originally posted by Bluedog View PostThese photos are the test piece.
Photo shows same piece with same prep work. Same amount of contam. if any. The soot weld is the opposite side of the same channel. Also, On syncrwave machines, miller recommends thoriated. False info?
Note: Tungsten is not getting dipped. Thanks all.
Use green (pure), ceriated, or my favorite, 2% lanthanated.
Griff
It is not even an issue as to whether or not it is contaminated...it is simply how it is occurring.
Are you purging your line before welding?
Looks like you either dipped or stuck your rod into the tung to me. Either way you need more practice. Not trying to be insultingjust stating the obvious. You may have fried your rod before you dipped it.
As far as using RED I am sure you read Millers info wrong.
I'll stare at those pics some more and see if maybe I missed something...I am in sort of a hurry now.
get some ceriated. I used to own a synchrowave 350. And that's all I ever used for steel and aluminum.
I also found that ceriated doesn't contaminate as easy as pure does when accidentally dipped in the aluminum puddle.
Thoriated is always for steel.
Some example photos of issue weld
Thoriated tungsten? for aluminum......
switch to pure or ceriated for aluminum.
That would be the first thing I tried.Last edited by FoxPerformance; 05-07-2009, 10:31 AM.
The contamination may be from the new jig, oil or something on it thats gassing due to heat on the part youre trying to weld. It could be diverting the sheild gas as well and possibly causing some turbulence possibly.
mike sr
Equip and settings
20 cfm argon
I would ask where the metal came from....like the channel just makes me think it could have some sort of coating like clear. If so it will mess with you pretty bad.
Pics could help a bunch on a post such as this because we are only guessing without them.
Equip and settings
20 cfm argon
The filler is balling due to being held too close to or too long in the arc zone.
GriffLast edited by griff01; 05-06-2009, 07:11 PM.
