I am working on a prototype concept, but I need some help.
Think of a stainless steel open top box 30" long x 24" wide x 10" deep. I need to run (8) 2.00" copper pipes, evenly spaced, thru the box, 5 inches off the bottom of the box. The pipes will run in the 30" long dimension. No problem punching the holes for the copper pipes. Heres the question. The copper pipe, where it penetrates each side of the Stainless box must be water tight as the box will be filled with water. The copper pipes will pass steam raising from a container of boiling water. The steam will not have any pressure, as the opposite end will be open to the air.
Can Copper/Stainless be welded, brazed, soldered ? How do I make that water tight joint ?
Thanks
KS2K
Thanks
KS2K
