Bandsaw
  • #31
    Originally posted by nikodell View Post
    Could be but they are psychically different in the photos.
    If they were physically different, I could tell from the photos. However, if you can tell that they are psychically different, you must be one of Dionne Warwick's "friends."
    • #32
      Kracker,
      The coolant system in the pic came from Harbor Freight also (now discontinued). The pump itself did not last very long and I am now using a Little Giant pond pump but still using the same resivoir and plumbing from HF.
      Larry
      "I feel for the man who can only spell a word one way"......Mark Twain
      Lincoln AC225-S (OLD/Copper Wound)
      Lincoln Weldpac 100
      Miller Matic 180 (auto set)
      Miller Spool gun 100
      Miller Spectrum 375 Extreme
      Victor Super Range II
      • #33
        Motor casings look different is all I am saying, also if you look at online manuals. I was thinking of getting on of these too but I have my doubts with the ability to actually set it up to cut a true 90 in the blade plane. Seems you can only true them through force on the blade which is not the correct way to get this done as it will ware guide bearings and shorten the life of the blade.
        Yha bad unchecked auto spell checker.
        • #34
          Originally posted by Can You Weld This For Me? View Post
          Milwaukee also makes a stand for their porta band making it like a chop saw. I bought one when I got the saw new, never used it, ended up giving it away for next to nothing. Now they are nearly as much as the saw. There are some interesting homebuilt porta band stands that folks have made. Once you use a porta band and get use to handling it, you will be hooked.
          CYWTFM: there....why did you have to come up with such a long name to type!!!!!!!!!!!! Anyway, how are THOSE portaband saws mounted????
          Very cool...........
          bert
          I'm not late...
          I'm just on Hawaiian Time
          • #35
            i really like that vertical saw mount. very good idea
            sigpic
            Miller Trailblazer 302
            Smith Torch Outfit
            Lots of Grinders
            Miller Elite Autodark Hood
            O'l Trusty Jackson
            • #36
              I too think the table stand is great,How is the saw attached to the stand? Mike
              • #37
                bert
                Hey guys, I definitely don't want to take credit for someone else's work. The one in the pic is not mine. Here's a link that tells about them:
                http://www.jalopyjournal.com/forum/s...d.php?t=323369
                I have a similar set up, but not quite as nice as this. I use mine free hand 99.9% of the time.
                • #38
                  CYWTFM, maybe my eyes, but from those 2 pics, I still didn't see how it was mounted! Thank you for posting though
                  bert
                  I'm not late...
                  • #39
                    bert
                    Sorry to keep reposting this huge pic, but I edited the one below so you could see the mounting holes. There are two 10-24 or smaller screws that normally hold a blade guide/rest onto the saw. If you remove it you have a nice flat surface to put the plate up against. I only use these two holes, the one in the pic I believe has three. I'd have to look at my saw, but the third one may have been tapped by the owner into the saw housing. Take a look and you will see the countersunk screw heads:
                    • #40
                      CYWTFM,
                      thanks you! and yes, and you're AWSOME
                      I'm not late...
                      • #41
                        Originally posted by Larwyn View Post
                        There is no doubt that the HF H/V bandsaw produces less than perfectly square cuts. However I have had little trouble getting close enough for welding purposes. If you need machine shop quality of cut, then you need machine shop quality machines. For the money, even with mods, I think my little HF bandsaw is an asset to my shop. With it I can make cuts quietly on Sunday mornings (not disturbing the neighbors, with out all the sparks and dust, and the parts are always cool enough to pick up immediately after the cut as long as I use the coolant pump.
                        [ATTACH]17782[/ATTACH]
                        Interesting photo. Could you tell us what some of the mods are? how do you collect the coolant?
                        Millermatic 211
                        Everlast 200DX TIG
                        Lincoln Weld-Pak 100
                        Century Stick welder
                        Hypertherm Powermax 30 plasma cutter
                        Oxy set-up with Henrob 2000 torch
                        Logan 200 lathe (60 years old)
                        Jet band saw
                        • #42
                          Bandsaw Help
                          Hi everyone,
                          Not sure if i am posting this in the right place, but here goes, i want to buy a cheap bandsaw and have seen the following model : Sealey Professional 200Mm Bandsaw 240V Model No: SM1303. for a reasonable price.
                          Has anyone ever bought one of these and are they any good ?
                          La mutuelle familiale de France
                          Devis mutuelle familiale des cheminots fr
