trailer coupler
  • trailer coupler
    hey guys I'm putting together a dump trailer and I got a 2'' coupler for the tongue and had planed on wedding it on but as I was looking at it, it said not to wed onto trailer. I know I have welded 4 or 5 on before and never had a problem before
    anyone know why they would say not to wed it on?
    Probably a stress thing, better off to bolt it.
      thats the only reason i could think of too.
      that and it would be alot faster fix if i ever needed to replace it for some reason
        I am not aware of the exact process but those hitches are hardened. Any welding on then will act as an annealing process but in an uncontrolled way. This can lead to failure due to many different reasons.
        Your better off to just bolt it. It is how they designed it.
          I bet its cause they aint sure who is doing the welding.
            I am with Sberry. Too much liability for lack of smarts.
              It's OK to wed your coupler if you're really in love and then you can get hitched
              Nick
              Miller 252 Mig
              Miller Cricket XL
              Millermatic 150 Mig
              Miller Syncrowave 200 Tig
              2-O/A outfits
              Jet Lathe and Mill
              Jet 7x12 horz/vert band saw
              DeWalt Multi Cutter metal saw
              Century 50 Amp Plasma Cutter
              Propane Forge
              60" X 60" router/plasma table
                sberry: is correct. and the manufacture know that there hitch is crap and will fall apart so they want you the bolt it so it will be easier to replace.
                TB 325
                TB 302
                dynasty 200sd
                spoolmatic 30a/wc24
                suitcase x-treme 12vs
                miller 211
                evolution rage 2
                  I worked for a trailer company and welded plenty of them on. We never had an issue.
                  Miller 330 A/BP Tig
                  Millermatic 250
                  Spoolmatic 30A
                  Hobart 175 mig
                  Miller Regency 250 w/ wire feeder
                  Bridgeport vertical mill
                  Delta bandsaw
                  Rockwell lathe
                    I've welded on a lot of truck frames, too. Except the ones that say "DO NOT WELD."
                      Every trailer I've ever built I've welded on the hitch coupler. Either used dual shield or ESAB E7018-H4R. Haven't had one break yet. A couple of the trailers have been used and abused pretty hard too.
                      Miller Trailblazer 302
                      Smith Torch Outfit
                      Lots of Grinders
                      Miller Elite Autodark Hood
                      O'l Trusty Jackson
                        lol that was a type-o
                          Dump trailer with a 2" coupler?? Must be a small one.
                            ya its a small 8x5 made from a boat trailer that had a 6'' I-beam frame and some other scrap steel i had. i haven't got the sheet steel for the sides yet
                            thats going to take me a week or two for the $$$
                            heres some pics of what i've done sofar
Name:	dump trailer1.jpg
Name:	dump trailer2..jpg
Name:	dump trailer3..jpg
                              Looks good. I can see that being overloaded very quickly.
                              MM250
                              Trailblazer 250g
                              22a feeder
                              Lincoln ac/dc 225
                              MM200 black face
                              Lown 1/8x 36" power roller
                              Arco roto-phase model M
                              Vectrax 7x12 band saw
                              Miller spectrum 875
                              30a spoolgun w/wc-24
                              RCCS-14
