speaking of the excalibur rods, i was wondering what makes them better than regular 7018. (or if there's anything different) i thought about picking some of them up today, but thought i would ask if there's anything better about them than say the esab 7018 H4R rods
Welding heavy steel with stick or mig welder
Excaliburs
Some 7018 H4R rods are known as "Jet Rods," and though are advertised as an "all position" rod, are really only good for flat or horizontal fillets (2F). Excaliburs are good for "9" positions, and (to me) perform better, especially uphill (fillets, overhead, & groove). Their availability is more common, especially in this part of the country.
Hobart "418's" are the better of their 7018's.
ESAB AtomArc are carried by a few local's here in Phoenix, but Lincoln's are more plentiful.
Demographics say a lot about equipment and consumables. 8 out of every 10 service trucks have a Trailblazer bolted on, and boxes of Lincoln rods in their toolboxesThere's still plenty of Classic 300's and Vantage engine drives running around though.
Speaking of "Big Red," they made some major "upgrades" in their engine drives this year. Can you say: "SAE 500?"
DaveLast edited by davedarragh; 04-03-2009, 09:26 AM."Bonne journe'e mes amis"
Originally posted by welderdude402 View Postspeaking of the excalibur rods, i was wondering what makes them better than regular 7018. (or if there's anything different) i thought about picking some of them up today, but thought i would ask if there's anything better about them than say the esab 7018 H4R rods
Originally posted by m.k.swelding View PostBelive it or not but I have done work on heavy equipment I have found that the 9018 1/4'' rod is the best for welding 3/4 and up the heat setting for this run between 225-275 amps. they weld much like a 7018. 5/32 rods are fine but the 1/4 is my pick. Good luckDylan
RED BIRD WELDING
"Experience is simply the name we give our mistakes"
HH-140
Crappy stick welder
Victor supper range II
Makita grinder
more stuff i don't feel like listing.
Originally posted by davedarragh View PostSome 7018 H4R rods are known as "Jet Rods," and though are advertised as an "all position" rod, are really only good for flat or horizontal fillets (2F). Excaliburs are good for "9" positions, and (to me) perform better, especially uphill (fillets, overhead, & groove). Their availability is more common, especially in this part of the country.
Dave
The Excalibur 7018 is an excellent rod.
The welders at our local refinery swear by the Atom Arc 7018.
Griff
Originally posted by griff01 View PostI believe the "Jet Rods" are the 7024 series.
GriffDylan
RED BIRD WELDING
HH-140
Crappy stick welder
Makita grinder
Originally posted by reggieits only being dragged behind a tractor not going to the moon...some peoples advice make simple things into megastructures...
Originally posted by davedarragh View PostMight want to double-check your resources, .068, .072, 5/64" are the only sizes available in my Lincoln book.
There's certainly nothing wrong with E-6011's, those that complain about them, generally don't know how to use them.
Griff
I usually use Lincoln's Code-Arc 7018's.... I think I'm going to order in some Esab Atom-Arc's and give them a try...Bobcat 225NT
Cutmaster 52
Lincoln Weld-Pak 100 buzz box
Caterpillar TH63
'07 Kawasaki ZZR600
"Jet Rods"
Griff
Jetweld 1 & 3 E7024
Jetweld 2 E 6027
Jetweld LH-3800 E 7028
Realizing the #2 refers to "postion"
However, their Jetweld LH-70 & 78 MR are restricted to 1,2,3,4 G & 2F
Jetweld LH-73 1,2,3,4,5 G & 2F
The Excaliburs are more versatile for 1,3,4 F Positions
Hope this clears up the "verbage" of "Jet Rods."
Actually, the "Jetset" extends to the higher psi rods, 8018, 9018, 11018, regarding the number of applicable positions.
Dave"Bonne journe'e mes amis"
E-6011's
Originally posted by BD1 View PostI thought 6011 was more of an AC rod and 6010 is the rod of choice for DC, not to mention it will work excellent on the old rusted farm machine steel. then use multiple stringers with 7018.
If you get the chance, try some Fleetweld 35's (6011) you'll see the difference between them and the 6011's you find at Home Depot & Lowe's.
The difference between 6010's & 6011's is primarily the flux.
EXX10 are cellulose-sodium
EXX11 are cellulose-potassium, which provides ionization of the arc, and more suitable for AC current. The same chemistry is used in the popular "7018 AC" rods.
DaveLast edited by davedarragh; 04-06-2009, 01:02 PM."Bonne journe'e mes amis"
