Bert... I worked on a major remodel of the tripler in the 80's....Ferdinand Marcos was holed up there at the time...We had to go thru security checks to get on the job site!
Welding heavy steel with stick or mig welder
Originally posted by bayweld View PostBert... I worked on a major remodel of the tripler in the 80's....Ferdinand Marcos was holed up there at the time...We had to go thru security checks to get on the job site!I'm not late...
I'm just on Hawaiian Time
"The Dirt On It"
Originally posted by chris_8126 View PostI guess I should have explained more clearly. I'm not quit sure of the thickness because I am still trying to find a blade to use. I found an old road grader blade that is 5/8" thick and I was looking for an old angle dozer blade. The blade of either is 12' wide and hopefully when I'm done the box scraper will move around 4 yards of dirt. If I had it finished now I would be using it to move sand that the river washed out across the field we farm. Lots of uses for one around the farm and we have several tractors 200+ hp to pull it. We have some old field cultivators that we don't use anymore I'm going to get other parts from. Here are a couple links showing an example.
http://www.garfieldequipment.com/products/hd.html
http://mancomanufacturing.com/bpm_8010.htm
Dave"Bonne journe'e mes amis"
Originally posted by BertPersonally I would stick it with 6011 then make passes after that with 7018.
Mig should be fine, up to you.
Practice with the mig, for layering/pad build up is the same. I find circles with my mig looks nicer.
Got any pics? How thick is the handle? Regular sch 40 pipe?
Good luck, and practice,practice practice...Originally posted by Bert View PostWELCOME TO THE FORUM!!!!!!!!
Both should work good for you.
What are you using for a handle? Sched 40 pipe??
Got any pics???
Personally, I'd stick it with 6011, then make passes over it with 7018.
Multi-passes/pad build-up same thing. Practice, practice, practice. Do you
have scrap of those thicknesses you can practice to join together???
WE ALL LOVE PICS HERE!!!!!!!!!!!!!!!!!!!!
Dylan
RED BIRD WELDING
"Experience is simply the name we give our mistakes"
HH-140
Crappy stick welder
Victor supper range II
Makita grinder
more stuff i don't feel like listing.
".045 nr-232?"
Originally posted by bretsk2500 View PostIf it was me, I'd either stick it w/ 5/32 7018 @160+ amps, or get some .045 NR232 and test out the duty cycle of the MM210. 6011 wouldn't come any where near it.
There's certainly nothing wrong with E-6011's, those that complain about them, generally don't know how to use them."Bonne journe'e mes amis"
Originally posted by davedarragh View PostMight want to double-check your resources, .068, .072, 5/64" are the only sizes available in my Lincoln book.
There's certainly nothing wrong with E-6011's, those that complain about them, generally don't know how to use them.Bobcat 225NT
Cutmaster 52
Lincoln Weld-Pak 100 buzz box
Caterpillar TH63
'07 Kawasaki ZZR600
Originally posted by Bert View PostWell, believe me, nothing's changed, 'cept more traffic and the housing prices have come down since last year...Now instead of my dad's house going for $750,000, it's down to $650,000. Maybe in a 1,000 years, I can afford my own!!!sigpic
Miller Trailblazer 302
Smith Torch Outfit
Lots of Grinders
Miller Elite Autodark Hood
O'l Trusty Jackson
Originally posted by welderdude402 View PostWOW! Prices down there are EXPENSIVE!! I'm looking into and just got my loan approval for my first house. It's got 3 acres, three machine sheds with the 40'x80' shop converted into a welding shop. The house is 4 BR and full basement w/2 baths. Lookin to get it for between 45-55K. You should definately move inland lol
yeah, dad bought his house for $19,000 in 1963. With Obama's plan, should be "worth" about $4 million soon!!!!!!!!!
I"m sure your house is nicer too!!!!!!!!!I'm not late...
eh your tricking me now? you HAD two of pretty much the some post right in a row
AH i must be spending to much time in the dark.Dylan
RED BIRD WELDING
HH-140
Crappy stick welder
Makita grinder
Originally posted by migwelder05 View Posteh your tricking me now? you HAD two of pretty much the some post right in a row
It's the POWER OF THE DELETE BUTTON!!!!!!!!!!!!!!!!!!!!!!
I"ve been going to bed between 2-4am every morning this week.
Must have been a little blurry myself
So no, wasn't youI'm not late...
I have a Thunderbolt xl 300/200 ac/dc. I weld on dc 99% of the time. I guess I just didn't know if the mig would be enough welder to burn in deep. I would say the pieces will be 1/2" to 3/4". I'm pretty sure we use 1/8" 6011 rods for most deep penetration on rusty metal here on the farm. I have made some repairs with a 6011 pass followed by two 7018 passes of the same size. Should I bevel one piece when butting it up to the other to get a deeper weld. Thanks for all the help!
Originally posted by chris_8126 View PostI have a Thunderbolt xl 300/200 ac/dc. I weld on dc 99% of the time. I guess I just didn't know if the mig would be enough welder to burn in deep. I would say the pieces will be 1/2" to 3/4". I'm pretty sure we use 1/8" 6011 rods for most deep penetration on rusty metal here on the farm. I have made some repairs with a 6011 pass followed by two 7018 passes of the same size. Should I bevel one piece when butting it up to the other to get a deeper weld. Thanks for all the help!
Got some mock up pieces to show us??I'm not late...
Originally posted by Bert View PostDepending on the configuration, you bevel one piece, or double-bevel it, or bevel both pieces. either way, it's too thick NOT to bevel it!! You won't get 100% penetration if you don't bevel.....
Got some mock up pieces to show us??Bobcat 225NT
Cutmaster 52
Caterpillar TH63
'07 Kawasaki ZZR600
Very Good Point: bretsk2500
Originally posted by bretsk2500 View PostNo, there's nothing wrong with 6011, but they shouldn't be used on anything that's going to receive a lot of impacts. That scraper is going to see a LOT of impact loads.
chris: Glad to hear you have the "real" Thunderbolt.Watch your duty cycle, though, with 5/32 7018's you'll be running toward the "top" of the DC+ current range. If you have a plasma, and a steady hand, making those bevels is a lot easier (or cutting torch).
With good joinery and fit-ups, I'm sure we'll be seeing pictures of your "chriscavator" in action.
Keep us posted of your progress.
