cause of welding explosion
  • cause of welding explosion
    Would like to understand the cause of an explosion
    Car was an chromemoly tube chassis car, with electroic fuel injection and a front mounted aluminum fuel cell (in grill area) that was full of alcohol. The guy was welding on the intake (aluminum) throttle linkage area, not sure where his ground was but the aluminum fuel tank exploded and split apart a the seams and caught fire. Would like some opinions on how this could have happened
    thanks
    Tank vent? All it would take is one well placed spark
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
      I'm not sure but I do believe the vent was not anywhere near the weld area. I am well aware of vapors that would be my first guess but I was wondering if welding ac on the aluminum could have produced a spark/arc in the fuel cell (bad welding ground)
        If it was FULL of fuel there should not have been a explosion, no air no fire.
        How ever if just a little bit of air gets in then it will burn.
        With out more info it is all a guess, and mine is air and a spark got in the tank.
        Be safe
        Jeff
        Give more than you get and
        you will get more than ya need.
        This is true for the good and bad
        that life puts out.
          Was anyone injured? More details please. Dave
            The fumes are heaver than air so any vapor escaping would fall to the ground.
              i was unaware that alcohol vapor was so explosive? How big is this tank? I would guess if it was small then it would have to be almost empty to produce enough vapor for a significant explosion. Either way it would seem that the proper precautions were not taken.
              Millermatic 175
              Spectrum 375
              All kinds of Smith OA gear
                Was it filled with methanol or ethanol? Methanol can burn in an enclosed space like a fuel tank, it's LEL is 4X higher than gasoline.
                Bobcat 225NT
                Cutmaster 52
                Lincoln Weld-Pak 100 buzz box
                Caterpillar TH63
                '07 Kawasaki ZZR600
                  IMO anybody who welds on a component under the hood on an assembled engine is pretty much taking a big risk anyhow. There are batteries and even crankcase fumes to deal with besides the fuel risk
                  I would say that the ground placement would be the key to your answer.
                  I am sort of assuming the tank was for the fuel when using nitrous...if so then the system may have become part of the welding circuit.
                  Miller WC-115-A
                  Miller Spectrum 300
                    An explosive mixture of air and fuel received enough activation energy to ignite.
                    There are endless possibilities of exactly how that could have happened. Think about the important variables... welding process, fuel level of tank, vent location, temperature of the fuel, ground lead location, ventilation conditions.
                    It is 100% impossible to do more than wildly speculate as to the contributing factors using the limited information you provided.
                    The important thing to note is that fuel vapors do travel and can sometimes be in an explosive concentration many feet away from the source.
                    With more information, such as pictures, we can do more than speculate. But if there is a liability issue, our words won't matter. Someone will have to consult a professional engineer specializing in forensic engineering.
                      One thing come to mind... the ground may not have been placed close enough to the work so the tank or its mount may have inadvertently become part of the electrical return path.
                        Spark + Vapors + Atmosphere = BOOM
                          Simply having current flow through a conductor that is in contact with a flammable environment will not cause an explosion.
                          If the ground clamp was connected directly to the fuel cell, and one or more of the connections in the circuit path were loose, this could have generated enough heat to boil a good deal of the flammable liquid out of the vent.
                          Still, this by itself would not have caused an explosion.
                            thanks
                            and there he is welding next to the fuel line? the possibility's never stop.
                            TB 325
                            TB 302
                            dynasty 200sd
                            spoolmatic 30a/wc24
                            suitcase x-treme 12vs
                            miller 211
                            evolution rage 2
                              It was the chromemoly tube chasis that caused it (sic)..
