Linde VI-252C and Linde wire feeder.
Hobart Cyberwave 300c.
HH 140.
Miller Big 40.
Lincoln SAE 200J.
Hobart GR-303.
Lincoln tombstone welder.
TD Cutmaster 52.
Hobart Stickmate.
Miller 211 w/ Spoolgun.
Lincoln SA 200.
So you want to know what is it we most often fix??
Well for me it would be busted skegs and leaking pontoon logs.
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
A keyless drill chuck. The ring that moves the jaws in and out had cracked. So I tigged it up.
Steve
I assume that you mean "fixed by welding" or just any repair.
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
I meant unusual and for some reason I clicked on the wrong word using spell check. I mean whats the most unusual thing that you have welded or fixed? Sorry for the confusion
Steve
Dont force it, use a BIGGER hammer.
HH 140.
Miller Big 40.
Lincoln SAE 200J.
Hobart GR-303.
TD Cutmaster 52.
Hobart Stickmate.
Lincoln SA 200.
Probably the strangest thing I have welded and it held was .........two of the four spider gears in the rear end of a 87 Dodge had some broken teeth. I built them up with mig and shaped with a grinder and reassembled. Worked fine. After I located new gears I replaced with new.
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
I fixed a tool that a rancher friend of mine uses. It is made to put rubber bands on Bulls for castration. Yes, I did wash it before, I touched it.
Wierd enough?
Peace,
Paul
Well, here's one I did not do. A friend of mine wanted to know if I could weld a buckle on his wife's handbag. Turned out it was a "Coach", (they're like $500), and I suggested he either take it back where they bought it (I believe a lifetime gaurantee), or a jeweler. Still trying to figure out where to attach a 500 amp ground clamp to a hand bag!
I welded the head back on a cast iron duck.....from that point on out it had a silver necklace on.....welded the cast aluminum grabbing teeth back on an echo chainsaw for my dad.....used tig on that and had to take the whole thing apart. Welded up some swinging rifle targets for the local pd also. Dave
I plastic welded my aunts little brackets that hold the grille on to the front of her car. Plastic welding sucks.
My last job I did alot of wax welding for the investment casting process.(that also sucked dingle berries.)
