Hi, all. I just got a shiny new spoolmate 100 for my MM180. I have welded aluminum with my old Lincoln using an 'aluminum kit' and the regular gun but this is my first spooler. I am getting black carbon soot around the weld bead. Not on it. I doesn't seem to affect the weld much except at the toes where there might be slight undercutting. The soot wipes off easily with a paper towel or at the most a light wire brushing.
What I have checked/tried:
I checked the gas circuit, gas flow tried various settings from 20 - 50 CFH.
I had the tank (new -just filled once) emptied and purged with nitrogen and refilled.
I tried cleaning the base metal with several solvents and then wire brushing with a new stainless brush.
I tried increasing/decreasing the stickout, travel angle, work angle and travel speed.
I tried varying the voltage and WFS.
The soot remains. I have welded some coupons and bent them to failure in a vice. The welds are generally good although some have failed at the toes.
Also, there is some arc instability when attempting fillet welds. The arc jumps to the horizontal piece and leaves a big hole in the weld bead.
The 'spray arc' hissing/buzzing sound sometimes comes and goes. At first I thought I was getting to close /far from the base metal but careful weld travel at a constant 3/4" stickout gives the same result.
I also checked the input voltage (240V 40 amp circuit) and the work lead contact. I am using .030 3035 wire and straight Argon gas, DCEP.
I am totally beside myself! This honey of a machine will do mild steel with C25 all day and you almost can't get a bad weld.
I hope some of you experienced aluminum jockeys can help.
Thanks,
DrBob
Thanks,
DrBob
