According to charts for thicker material you should use .035 but most welding shops say .030 works great on most applications with the millermatic machines. I own a MM211 welding between 1/8- 1/4 material using C02.
Mig wire size .030 or .035
Mig Wire
Originally posted by silvertown View PostAccording to charts for thicker material you should use .035 but most welding shops say .030 works great on most applications with the millermatic machines. I own a MM211 welding between 1/8- 1/4 material using C02.
For that thickness I would run .030, But that's just me, on my Lincoln 180 !
Miller Equippment may Differ ?
................. Norm
a lot of it's personal preference. they both will work alright, just depends on how much wire you want to feed in for a length of weld. i always went with the .035 cause you had the option of filling nfaster and whatnot.sigpic
Miller Trailblazer 302
Smith Torch Outfit
Lots of Grinders
Miller Elite Autodark Hood
O'l Trusty Jackson
Each wire has their window that they operate best in. For your range of material, especially when you get up in the 1/4" range, the .035 would work best. I personally use the .030 for most of my applications up to 3/16. The trailer project I did I used .035 since most of the material was 3/16 and 1/4 and I wanted it structurally sound.
.030 works real good in 22 ga up to 1/8 maybe 3/16
.035 works well from 16 ga up to 5/16
These are best window applications. Sure both sets of wire "can" weld thinner and thicker materials.
I would ask yourself "what am I going to be welding most?" and pick the best wire for that range.
Good luck
Andy
Sorry, not sure how to redirect you to the above thread. I believe you will find it very informative and pertinent to your subject matter.Geezer
Miller 175
Power MIG 255c
Ranger 8
1974 Wisconsin 5K AC Only (Cherry)
Spool Gun
185 TIG
Victor/Harris O/A
A lot of it will just depend on how often you want to change out the spool in the machine. If you like keeping one spool in there for just about anything that walks in the shop (within THAT machine's capabilities) you'll do just fine with .030" even though the .035" will give you a slight edge at times. Current density will be higher in the thinner wire and actually offsets some of the advantages of the thicker wire anyway, plus gives the the benefit of making it easier to weld thinner material.
Good thread,
I just purchased a new MM252 and installed a large spool of .035, C25 gas. I did some practice runs on some 1/4" plate, fillet, butt and vertical, worked just fine (little more spatter then I expected) I then ran some tests on some 1/8" and was not as impressed. (mind you I haven't run wire for nearly 10 years) I switched out to .030 and the finished product on the 1/8" was much better, and when I did some thinwall sq tube, some 10ga it was sweet!
I am leaving the .030 in the machine for most of what I am doing and when I crank it up to 1/4 and better, I will switch wire.
Question: any luck running .023 through the .030/.035 liner. (I purchased .023 guide rollers)
TimsigpicRetired Elevator Consrtructor Local 19 IUEC
AK bush pilot (no longer in AK) too old and no longer bold)
Chaplain CMA chapter 26
Dynasty200dx (new and loving it)
MM-252 (NEW AND LEARNING IT)
Hypertherm PM-45
Miller 140 mig 110v
Vtwin builder
.023 Wire
Tim
is not a problem !!
Enjoy your new welder !!
Thanks guys,
I did buy a .023 inlet tube and rollers for the New 252 I am looking forward to see how smooth the starts are at the low end? I have an old "Auto-arc" made by miller that uses only .023 and it is only so so for stitching sheetmetal.
Hypertherm PM-45
Miller 140 mig 110v
Vtwin builder
