hey guys im wanting to buy a plasma 375 xtreme. i have a craftsman air compressor with a 5.5 hp electric moter and a 33 gallon tank. the motor kicks out at 120 psi and kicks back on at 90 psi. im just wondering if my compressor has enough jam to run a 375. thanks
plasma and compressors
375 Extreme Plasma !!!
Originally posted by 57Belair View Posthey guys im wanting to buy a plasma 375 xtreme. i have a craftsman air compressor with a 5.5 hp electric moter and a 33 gallon tank. the motor kicks out at 120 psi and kicks back on at 90 psi. im just wondering if my compressor has enough jam to run a 375. thanks
You Have Enough Power & Pressure, No Problem !!
I'm running a 5hp. -- 20 Gal. Compressor ,No Problem Here !!
............. Norm
Re-boot
FWIW I turn my compresser up alittle higher and set the low pressure to a little higher and then regulate it on the line connected to my Plasma- (Hypertherm PM-45) It does much better there! Also I have a air dryer on the main run and another connected right at the plasma--From experience you will get better life from the consumables.
Hope that is heplful,
TimsigpicRetired Elevator Consrtructor Local 19 IUEC
AK bush pilot (no longer in AK) too old and no longer bold)
Chaplain CMA chapter 26
Dynasty200dx (new and loving it)
MM-252 (NEW AND LEARNING IT)
Hypertherm PM-45
Miller 140 mig 110v
Vtwin builder
